More racecar, less boat...
#2115456
07/22/16 12:53 PM
07/22/16 12:53 PM
Posts: 2,432 NorCal
RylisPro
NorCal
My car rocks like a boat. If I grab the front bumper I can easily rock my front up and down. When I grab the roll cage I can rock the car side to side just like my beater Corolla. I have always hated the undulating motion of the front end after a dip in the road. In comparison every other car at Sonoma Raceway was rock solid when I was trying to shake it until the owner chased me away. Even my S2000 with factory stock suspension doesn't move at all. Granted that most every car at the track had aero as in a front splitter/ huge rear wing and was running stiff springs to compensate. I think the issue is the Hotchkis pieces. I run their leaf springs, single adjustables and 1.12 TB's. The components work well as its all balanced, but it is a compromise between handling and ride quality. Since single adjustables only control rebound and I think I may need doubles in order to control compression. Anyone use a set of doubles for dedicated track use only? Road course not drag race haha! Does any company make a custom bolt in set for our cars? Being the only old school Mopar out there kind of sucks haha!
Re: More racecar, less boat...
[Re: RylisPro]
#2115511
07/22/16 02:23 PM
07/22/16 02:23 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
They aren't custom, but they are supposed to bolt in. Here's my thread. I should be getting them on Monday. There's also QA-1, Vi-king (who offers custom re-valving), amongst others.
[Re: RylisPro]
#2115738
07/22/16 07:46 PM
07/22/16 07:46 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Ask Mitch about your 1.12" "beginner" Tb's. IMO, you could step the TB's up, and if I didn't know about your tire rim package, that would be my first question, but you do have a nice wide /low aspect stiff side wall tire set-up, right?
[Re: RylisPro]
#2115761
07/22/16 08:09 PM
07/22/16 08:09 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I should have listened to Mitch all along. He told me to go 1.24's a while back haha! He's going to post on here "I told you so!" Problem with stepping up to thicker torsion bars is you have to find that balance again with the rear leafs and have matching shocks to compensate. More money down the drain. Luckily I did talk to Jon at Hotchkis and he said that you can have their single adjustable shocks re-valved for a small fee. Yes I have a square setup and will go to 315's eventually after my 295's are used up. I may need to go with a stiffer TB so that my fenders don't get chewed up by the tire when the suspension is compressed on a banked turn.
[Re: GoodysGotaCuda]
#2115764
07/22/16 08:13 PM
07/22/16 08:13 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Get shocks you can dial in.
Just jumping up on spring rate is not necessarily the first step I would take. Good point Goody thats the plan! With my current setup I am at 2 clicks until full stiffness for the front shocks. Jon at Hotchkis said they were about the same for their car as well. With re-valved shocks hopefully I can have further adjustment. I would rather have singles over doubles anyway for the simplicity
[Re: RylisPro]
#2115777
07/22/16 08:35 PM
07/22/16 08:35 PM
Posts: 106 Central IL
Trojmn
Central IL
x2 on the spring rate. you only need as munch spring rate to keep the car off the ground and then whatever more to control body roll to keep the tires happy.
it sounds like your issue is all shocks... you likely have one or more that need rebuild and/or not enough rebound valving.
on a side note check your swaybar bushings and endlinks. that will somewhat contribute to wobble after bumps.
[Re: RylisPro]
#2115868
07/22/16 11:12 PM
07/22/16 11:12 PM
jcc
Bitopia
"Problem with stepping up to thicker torsion bars is you have to find that balance again with the rear leafs and have matching shocks to compensate. More money down the drain."
I wouldn't make to many changes right now, until you make the tire upgrade, unless collecting switched out parts is the objective. I'm too lazy to go out and test for myself, how much qa1 adjustability can be felt by simply low speed bouncing the car at rest as per the OP's observation of an installed shock. I do know how a stiffer spring/TB will react to the same test. Tire scrub distorts the observation however.
[Re: RylisPro]
#2116102
07/23/16 01:04 PM
07/23/16 01:04 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I have double adjustable Vikings, turning up the compression damping feels just like changing to a stiffer spring, you can balance the car front to back very easily....get some before you buy new bars.
A new iron curtain drawn across the 49th parallel
[Re: RylisPro]
#2116449
07/24/16 01:29 AM
07/24/16 01:29 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Ariel, have you weighed or scaled the car since the ALL ALUMINUM Gen III was installed? My one and only Autox I have participated in my car was a talking subject for a few observers. They were very impressed with how "flat" my car stayed. I have the biggest T-bars I can get and not ideal rear springs yet. I also have non-adjustable Hotchkis shocks but I also have non bushed endlinks.
Mopar to the bone!!!
[Re: 72Swinger]
#2116710
07/24/16 04:22 PM
07/24/16 04:22 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Ariel, have you weighed or scaled the car since the ALL ALUMINUM Gen III was installed? Hey Emil, Yes the car weighed about 80-85 lbs. less since the engine swap and I recently took out the wiper motor and blades/parts. The car corners well and flat, not too much body roll.
[Re: RylisPro]
#2117910
07/26/16 03:49 AM
07/26/16 03:49 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I have a set of big t-bars you could come up and install on lift to try out. Haven't put them in the AAR yet. Maybe pick a track day at Thunderhill and come up a day early. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: moparx]
#2118021
07/26/16 12:14 PM
07/26/16 12:14 PM
Posts: 5,392 Pikes Peak Country
TC@HP2
Pikes Peak Country
if the spring or wheel rate is on the soft side, how much bigger can a guy go up in sway bar size to compensate ? providing the bar sizes are correctly matched front and rear ? Depends on the roll couple of your car's combo. Unfortunately it isn't a universal relationship. My car can use a .92" t-bar and a 1.25" s-bar and have the same roll couple % as 1.12" t-bar and a 1.125" s-bar or a 1.22" t-bar and a 1" s-bar. Add a rear s-bar and these all change. Rear bar mounting style also impacts rates as well since there are variations in this configuration as well.
[Re: RylisPro]
#2118215
07/26/16 04:44 PM
07/26/16 04:44 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
RylisPro -- IMO... since you're intending on the usage of the car more towards track (road course and/or AX/HSAX/HPDE)... then by all means go stiffer on the TBs. The small TBs (~1.12) definitely show improvement over the smaller factory TBs... but for track duty something like the 1.18-1.20-1.22-1.24 will progressively stiffen the car from lifting/diving/leaning... and that sounds just what you're in need of. The bigger TBs (say, up to the 1.24 for example) will make you only wonder, as I've said many times before, why you just didn't install these in the first place so to save the work, experience, labor, and cost, etc... The larger TBs (~1.24) are still very street/hyw-able... they are stiff, but not unbareable. Call FF and order them sooner rathjer than later... 1.24 is the largest physical size that fits in out 1.25 hex opening.
Shocks? Although I have old red "D" Konis, and they were re-valved a little stiffer after a while, today I'd buy dbl-adjust.. QA1, Viking, etc... you can truly tune the ride.... I will be getting these ~the next 1-2 years for my car (still all apart for this year).
Tire pressures can also adjust the ride, etc.
Sway bars are for tuning the lean... they have nothing to do with lift or dive.
When driving hard... real hard, as in track time, and pushing your limits, you want a stiffer suspension. Retail "packages" (Hothckis, example) do compromise the handling... they're far better than stock.. but better for true competition is available.
My car is balanced side-to-side, corners flat, minimal lift or dive when accelerating or breaking, steering reacts quickly, rides like on rails... 1.24 TBs, 225#/5" fiberglass FlexAForm mono leafs, Konis, front sway bar 1.25", rear sway bar 1.0", ~3200# w/o driver and ~1/4 tank fuel... 52% front, 48% rear. A joy to drive and race (forget about "street" as you have to watch the pot-holes, bumps, etc... consider hwy and track as the places to drive).
Your car is awesome and is right up there with the best of them! The "project" never seems to end... time (track time) to make adaptations, etc., \will get you better desired results.
Don't be afraid of larger TBs (~1.24 diameter)... contact FF and they'll make them for you (they may have some in-stock).
Also, yes, a little stiffer rear suspension to balance with the bigger front TBs should be done.
MoPower to ya!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2118316
07/26/16 05:52 PM
07/26/16 05:52 PM
Posts: 2,432 NorCal
RylisPro
NorCal
My current setup is pretty good for now and when it is time I need to replace tires for wider ones is when I will see if the need to switch over to thicker TB's. Probably next summer. The thicker TB's would be the easy part as FF has them. I will have to research Flex-a-Form for the leafs and revalve all the shocks for a higher rate. For now I will just enjoy the car at the track as much as possible as I still want to make it to the 2017 Spring Fling track event. In the meantime I will get 1.24's, matching leafs and other parts and swap the all at once when I switch to 315's
[Re: RylisPro]
#2119107
07/27/16 03:12 PM
07/27/16 03:12 PM
Mopar Mitch
RylisPro - FlexaForm will ask you the weight of the car, in particular the rear corner weights (lr, rr)... and the intentions of your driving the car. For handling purposes, you want the leaf spring to be relatively flat during most driving... say maybe ~1" arch free-standing ( that's what I have... as setup primarily for AX competition). IF you have rough roads, that's another consideration; flat roads (road course and AX) are typically flat.. so.. that's where you can consider to have a more flat-at-rest leaf spring; bouncing roads would favor more arch, but then handling advantages go away. Compromising becomes the issue.
Mopar Mitch
[Re: Mopar Mitch]
#2119191
07/27/16 05:14 PM
07/27/16 05:14 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey Mitch, Yeah I need to get those rear weights and talk to Flex-A-Form. I mainly use the `Cuda on track events but then again I drive my car to the racetrack. I'm too poor to own a trailer haha! 360 miles to Willow Springs from where I live and 360 miles back. Mostly freeway mileage so there are some rough roads. Question for you, how is the durability of a fiberglass leafspring? It's difficult for me to comprehend replacing a proven steel leafspring with a fiberglass one. Thanks!
