727 parts ?'s #2115131
07/21/16 09:54 PM
07/21/16 09:54 PM
md
W
wicked Offline OP
wicked  Offline OP
W
md
Picked up a sb 727. Ran the #'s on the case and it a 66 case. Did some research here and elsewhere and ran into conflicting info on weather it should be 19 or 24 splines. This one has 24. I understand they can be swapped as long as other parts from the donor are used, but I'm not sure exactly which parts. I haven't torn it down yet. Looking for info on pumps, shafts, etc so I know what to look for and correct in the event I run into miss matched parts. Any help appreciated and thanks in advance.
Re: 727 parts ?'s [Re: wicked] #2115589
07/22/16 03:49 PM
07/22/16 03:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A '66 was originally 19-spline but it's quite common to find them updated to the 24-spline input....the input shaft and the reaction shaft support must be swapped as a pair.
From a replacement parts standpoint, the main issue would be if the swapped parts were from a '67-70 or '71-later. '71-later had different sealing rings, piston seals and front drum bushing.
Re: 727 parts ?'s [Re: John_Kunkel] #2115617
07/22/16 04:24 PM
07/22/16 04:24 PM
md
W
wicked Offline OP
wicked  Offline OP
W
md
Thanks for the info. I believe the support 71 up has wider bushing, any way to tell the difference on the shafts and pumps? casting #'s on the pump or stator support? I think I am going to pull it apart tonight so I can get a better idea.
