Re: Hoosier drag slick (Raidial)
[Re: Biginchmopar]
#2114921
07/21/16 04:45 PM
07/21/16 04:45 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
From what I understand, radial slicks and clutches aren't the hot ticket.
[Re: Biginchmopar]
#2114926
07/21/16 04:53 PM
07/21/16 04:53 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
The hemi super stock cars seem to make it work OK
[Re: Biginchmopar]
#2114930
07/21/16 04:56 PM
07/21/16 04:56 PM
fast68plymouth
So. Burlington, Vt.
With a stick?
I don't know of any Stockers who run radials with a stick, and in Stock the radial is the much preferred tire.
I'd say contact the manufacturer of the tire you're looking at running and get their feedback on how you want to use the tire......... On a Heavy car with an aggressive clutch.
[Re: fast68plymouth]
#2114972
07/21/16 05:37 PM
07/21/16 05:37 PM
B3422W5
Portage,michigan
With a stick?
I'd say contact the manufacturer of the tire you're looking at running and get their feedback on how you want to use the tire......... On a Heavy car with an aggressive clutch. The SS/ AH cars run radials these days.
[Re: Biginchmopar]
#2114975
07/21/16 05:42 PM
07/21/16 05:42 PM
fast68plymouth
So. Burlington, Vt.
Something has changed then...... From an interview with John Holt(SS/AH chassis builder) from a few years ago:
"Holt: Sticks run faster. But just to clarify, NHRA didn’t give them the advantage. Remember they use to run the stick and automatics as separate classes. It was the automatic cars that triggered the index shift, so when they put the classes together, that’s just where it ended up. I don’t think that it’s a factor though. Sure the stick is quicker and gives you 2 to 3 more horsepower, but it’s hard to drive. There is a lot going on for the driver, not only at the line but three times down the track. As for the automatics they have an advantage of 5 to 6 hundredths, because they can use the radial tires. Sticks can’t use the radials. It’s has to do with the way the tire is designed and the way the stick cars launch. So each has their advantages and in reality most people can’t get their cars that light anyway. So the decision is in what’s best for the driver."
I'm pretty confident in saying that a heavy car with an aggressive clutch and a set of radial slicks will not result in "smiles all around".
[Re: B3422W5]
#2114976
07/21/16 05:43 PM
07/21/16 05:43 PM
Triple Threat
Renton Washington
With a stick?
I'd say contact the manufacturer of the tire you're looking at running and get their feedback on how you want to use the tire......... On a Heavy car with an aggressive clutch. The SS/ AH cars run radials these days. You can't compare a $250K purpose built racecar to most small tire stick cars. Radials don't work well with small tire stick cars. Stick to a Bias ply.
[Re: Biginchmopar]
#2114980
07/21/16 05:50 PM
07/21/16 05:50 PM
B3422W5
Portage,michigan
Nobody mentioned anything about money. Dwayne didn't seem to know those guys run radials now. A radial is without a doubt faster. That isn't debatable. That said, it's less forgiving, no doubt about it. But most guys aren't making 900+ horse like a SS/AH car is either.
[Re: Biginchmopar]
#2114983
07/21/16 05:53 PM
07/21/16 05:53 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
B3422W5...Are you sure the STICK cars in SS/AH are running radials??? We know the automatics do.
[Re: Biginchmopar]
#2114987
07/21/16 06:04 PM
07/21/16 06:04 PM
B3422W5
Portage,michigan
I thought Charlie told me at 131 summer before last they were running radials. Somebody more familiar can jump in, but I thought that's what he said
[Re: Biginchmopar]
#2115009
07/21/16 06:33 PM
07/21/16 06:33 PM
B3422W5
Portage,michigan
Looks like a bias tire, not a radial. Guess I am getting old
[Re: Biginchmopar]
#2115041
07/21/16 07:18 PM
07/21/16 07:18 PM
Posts: 104 Washington
weedburner
Washington
Tire manufacturers are not going to have the answer, as there is a lot more to it than just the tires.
The clutch is the key to getting radials work with a clutch shifted stick. You need the clutch clamp pressure to come in soft enough to eliminate rpm drop on the launch. Also soft application of clutch clamp pressure just after the shifts, which drags rpm drop out over a longer time period, which in turn minimizes shock to the tires. Easiest way i have found is to temporarily hold back some clutch clamp pressure at the throwout bearing. Do this, it's easier to make radials work behind a stick than it is to make them work behind an automatic.
With a clutchless trans it's much harder to make a radial work, unless you think outside the box. The launch isn't too hard to get down with an adjustable clutch, but the typical adjustable clutch uses centrifugal assist, which means clutch clamp pressure is going to be at it's maximum when you pull the lever. This puts a huge instantaneous shock into the tires, until rpm drops far enough to allow the clutch to begin slipping. Unless you have a way to kill some clutch clamp pressure just after the shifts, radials and a clutchless shift with a typical adjustable clutch are not a good combination. You might be able to get a Lenco to shift soft enough, but it's going to be really hard on the Lenco's relatively small internal friction material.
[Re: Biginchmopar]
#2115128
07/21/16 09:52 PM
07/21/16 09:52 PM
fast68plymouth
So. Burlington, Vt.
I think with regards to the OP's particular combo, it's going to be a matter of balancing the launch rpm and tire pressure to come up with the right amount of spin that provides decent 60' times without breaking parts. If you try for "dead hooking", it's just going to break(or, if you leave too low ..... bog).
#2115218
07/21/16 11:33 PM
07/21/16 11:33 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I think with regards to the OP's particular combo, it's going to be a matter of balancing the launch rpm and tire pressure to come up with the right amount of spin that provides decent 60' times without breaking parts. If you try for "dead hooking", it's just going to break(or, if you leave too low ..... bog). This is exactly what I did - Broke parts, fixed that then bog now, I'm looking to calm that down and gain some gear. Hoosier has a nice 30x10.5 29.5" actually radial 12.5" section width. I get what most are saying about the radial tire so I'll keep looking at my options.
