Washer Pump Ground Wire #211463
02/01/09 11:29 PM
02/01/09 11:29 PM
Dallas, TX
70challrtse Offline OP
super gas
super gas
Dallas, TX
Which hole is the negative ground wire attached to on the washer bottle in my 70 Challenger? Thanks
Re: Washer Pump Ground Wire [Re: 70challrtse] #211464
02/01/09 11:31 PM
02/01/09 11:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bottom one, because I don't think the lead will reach either one of the top holes
Re: Washer Pump Ground Wire [Re: gtx6970] #211465
02/01/09 11:39 PM
02/01/09 11:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From the back side;
Re: Washer Pump Ground Wire [Re: Alaskan_TA] #211466
02/02/09 08:58 AM
02/02/09 08:58 AM
Dallas, TX
super gas
super gas
Dallas, TX
From the back side;
Thanks Barry,that's what I need. I finally found the correct pump with the ground wire connector that snaps into the bottle. Do I still use the washer that comes with screw where the ground wire connects?
Bill, the ground wire I have on my repop washer is long enough to reach any of the holes, but you are correct about the OEM pump - the wire is not as long. Thanks.
Re: Washer Pump Ground Wire [Re: 70challrtse] #211467
02/02/09 05:17 PM
02/02/09 05:17 PM
cataclysm80 Offline
cataclysm80  Offline
Tav
Re: Washer Pump Ground Wire [Re: 70challrtse] #211468
02/03/09 09:06 AM
02/03/09 09:06 AM
Dallas, TX
super gas
super gas
Dallas, TX
Do I still use the washer that comes with screw where the ground wire connects? Thanks.
Sorry to this but could someone please help me with that question.
Re: Washer Pump Ground Wire [Re: 70challrtse] #211469
02/03/09 11:24 AM
02/03/09 11:24 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ron,
the correct screw has a captive washer that can't be removed.
Re: Washer Pump Ground Wire [Re: gtx6970] #211470
02/03/09 11:33 AM
02/03/09 11:33 AM
Dallas, TX
super gas
super gas
Dallas, TX
Ron,
So where the ground wire attaches a different screw is not used? Thanks.
Re: Washer Pump Ground Wire [Re: 70challrtse] #211471
02/03/09 12:40 PM
02/03/09 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ron,
no
Re: Washer Pump Ground Wire [Re: 70challrtse] #211472
02/03/09 01:25 PM
02/03/09 01:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
same screw in all 3 locations of the reservoir
