truck oil pan dip stick #2114637
07/21/16 10:57 AM
07/21/16 10:57 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
What is the best way to plug the oil dip stick hole on a 440 block. Putting a deep pan on a truck and can not use the one on the block. Motor is in the truck.
Re: truck oil pan dip stick [Re: 68dodge] #2114919
07/21/16 04:42 PM
07/21/16 04:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Pull the dipstick housing out of the block, cut it off 1/4" above the block, weld it closed, re-install the "stub" back into the hole with sealer. gene
Re: truck oil pan dip stick [Re: 68dodge] #2115558
07/22/16 03:27 PM
07/22/16 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Squirt the hole full of RTV.
Re: truck oil pan dip stick [Re: 68dodge] #2117347
07/25/16 03:09 PM
07/25/16 03:09 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Does the truck have the truck oil pan and dipstick now? If so the dipstick doesn't go into the block, it goes into a fitting on the pan. If this is the case, then the hole in the block is already plugged.
