Re: Washer Pump Ground Wire
[Re: Alaskan_TA]
#211466
02/02/09 08:58 AM
02/02/09 08:58 AM
Posts: 2,852 Dallas, TX
70challrtse
super gas
super gas
Dallas, TX
From the back side;
Thanks Barry,that's what I need. I finally found the correct pump with the ground wire connector that snaps into the bottle. Do I still use the washer that comes with screw where the ground wire connects?
Bill, the ground wire I have on my repop washer is long enough to reach any of the holes, but you are correct about the OEM pump - the wire is not as long. Thanks.
[Re: 70challrtse]
#211468
02/03/09 09:06 AM
02/03/09 09:06 AM
70challrtse
super gas
super gas
Dallas, TX
Do I still use the washer that comes with screw where the ground wire connects? Thanks.
Sorry to this but could someone please help me with that question.
[Re: gtx6970]
#211470
02/03/09 11:33 AM
02/03/09 11:33 AM
70challrtse
super gas
super gas
Dallas, TX
Ron, the correct screw has a captive washer that can't be removed.
So where the ground wire attaches a different screw is not used? Thanks.
[Re: 70challrtse]
#211471
02/03/09 12:40 PM
02/03/09 12:40 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
no
[Re: 70challrtse]
#211472
02/03/09 01:25 PM
02/03/09 01:25 PM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
same screw in all 3 locations of the reservoir
