Plug wires, life span?
#2113172
07/19/16 11:55 AM
07/19/16 11:55 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have some older plug wires that test just fine on the ohm meter, but thought it wouldn't hurt to find out what others consider when determining that they are do for replacement. There is no sign of age on them, and like I said, ohms readings are good. Post your thoughts, thanks!
Re: Plug wires, life span?
[Re: gregsdart]
#2113174
07/19/16 11:58 AM
07/19/16 11:58 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I'm wondering this myself. The MSDs on my hemi are 10 years old, but they ohm good. The MSDs on my wedge motor are probably 14 years old.
[Re: gregsdart]
#2113216
07/19/16 12:47 PM
07/19/16 12:47 PM
Thumperdart
State of confusion
Grab em when it's running then you'll know for sure........... Was told that ohmage is only part of the equation and actually changes and they get older but my Firecore`s are at least 8 years old and still kickin. Start it up in a dark garage and check around the boots and see what that does and I take the boots off of em and apply silicone on the wire then slip the boots on and let cure for 24 hrs which helps............
[Re: lewtot184]
#2113266
07/19/16 01:39 PM
07/19/16 01:39 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Almost all of the outer layered helical stainless spun spark plugs wires use a inner graphite coated conducter for the spark to travel on I had one set of Moroso older wires that ohmed good but wouldn't run worth a hoot on my motor, it wouldn't hardly idle or stay running once started The higher the revs and the higher the internal resistance in the cylinders(compression, boost and fuel type) the higher the amperage needed to fire the plug and the higher load on the wires and plugs Wires do wear out, especially the coil wire
[Re: gregsdart]
#2113284
07/19/16 02:03 PM
07/19/16 02:03 PM
Posts: 11,658 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I was told by a tech person at Autometer years ago. Replace wires every year. Coil wire every 6 months. I haven't maybe been that religious, but depending on the run time they don't stay on past 2 years
[Re: gregsdart]
#2113303
07/19/16 02:26 PM
07/19/16 02:26 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
My last set of Taylors were at least 15 years old.Still worked great but looked bad.My kids were at least 6 years when he sold his 300.Rocky
Chrysler Firepower
[Re: gregsdart]
#2113304
07/19/16 02:26 PM
07/19/16 02:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A shop I use to work at we did drive ability and we tested wires all the time...when you have the meter on them flex them around and see what the meter says... on a lot we could see that they would really change and some would go open... those wires move around on a engine.. specially on our rigid mounted engines... keep them away from heat... cheap wires dont last long but a quality set can last years but also.. keep them clean
[Re: CMcAllister]
#2113362
07/19/16 03:42 PM
07/19/16 03:42 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I was told by a tech person at Autometer years ago. Replace wires every year. Coil wire every 6 months. I haven't maybe been that religious, but depending on the run time they don't stay on past 2 years This is the way I look at it also. Wires are a ware item just like plugs and oil. I have a few sets laying around that will work ok on street stuff.
[Re: gregsdart]
#2113560
07/19/16 08:49 PM
07/19/16 08:49 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
They need to be Hipot tested, its done by a Megger. that is what is used to test the leakage and breakdown of the wire. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: gregsdart]
#2113679
07/19/16 11:17 PM
07/19/16 11:17 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
i have a friend that had as big block and turbo in his 80 Camaro. he had a miss he couldn't find. took the wires off ( msd) and they checked out ok, so he didn't replace them. after spending a lot of money chasing his tail, another friend asked him, when he was checking the wires, did he just checked them holding them straight, or did he bend them as he tested them..... turns out 5 of the wires went open if he checked them while bending them, just like the would be on the car. replaced them, and the miss went away.
but i would also say, that high compression, boost, and nitrous take their toll on wires. on a NA engine the wires would live longer.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
