Plug wires, life span? #2113172
07/19/16 11:55 AM
07/19/16 11:55 AM
gregsdart Online content OP
gregsdart  Online Content OP
I have some older plug wires that test just fine on the ohm meter, but thought it wouldn't hurt to find out what others consider when determining that they are do for replacement. There is no sign of age on them, and like I said, ohms readings are good. Post your thoughts, thanks!
Re: Plug wires, life span? [Re: gregsdart] #2113174
07/19/16 11:58 AM
07/19/16 11:58 AM
an8sec70cuda Offline
I'm wondering this myself. The MSDs on my hemi are 10 years old, but they ohm good. The MSDs on my wedge motor are probably 14 years old.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Plug wires, life span? [Re: gregsdart] #2113216
07/19/16 12:47 PM
07/19/16 12:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Grab em when it's running then you'll know for sure........... laugh2 Was told that ohmage is only part of the equation and actually changes and they get older but my Firecore`s are at least 8 years old and still kickin. Start it up in a dark garage and check around the boots and see what that does and I take the boots off of em and apply silicone on the wire then slip the boots on and let cure for 24 hrs which helps............
Re: Plug wires, life span? [Re: gregsdart] #2113248
07/19/16 01:28 PM
07/19/16 01:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if they past the ohm test and the insulation is good run'em.
Re: Plug wires, life span? [Re: lewtot184] #2113266
07/19/16 01:39 PM
07/19/16 01:39 PM
Almost all of the outer layered helical stainless spun spark plugs wires use a inner graphite coated conducter for the spark to travel on work I had one set of Moroso older wires that ohmed good but wouldn't run worth a hoot on my motor, it wouldn't hardly idle or stay running once started shruggy
The higher the revs and the higher the internal resistance in the cylinders(compression, boost and fuel type) the higher the amperage needed to fire the plug and the higher load on the wires and plugs work Wires do wear out, especially the coil wire scope
Re: Plug wires, life span? [Re: gregsdart] #2113284
07/19/16 02:03 PM
07/19/16 02:03 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I was told by a tech person at Autometer years ago. Replace wires every year. Coil wire every 6 months. I haven't maybe been that religious, but depending on the run time they don't stay on past 2 years
Re: Plug wires, life span? [Re: gregsdart] #2113295
07/19/16 02:16 PM
07/19/16 02:16 PM
Thanks, all. These wires are probably old enough, even with limited use.
Re: Plug wires, life span? [Re: gregsdart] #2113303
07/19/16 02:26 PM
07/19/16 02:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My last set of Taylors were at least 15 years old.Still worked great but looked bad.My kids were at least 6 years when he sold his 300.Rocky
Chrysler Firepower
Re: Plug wires, life span? [Re: gregsdart] #2113304
07/19/16 02:26 PM
07/19/16 02:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A shop I use to work at we did drive ability and
we tested wires all the time...when you have the
meter on them flex them around and see what the
meter says... on a lot we could see that they would
really change and some would go open... those wires
move around on a engine.. specially on our rigid
mounted engines... keep them away from heat... cheap
wires dont last long but a quality set can last years
but also.. keep them clean
wave
Re: Plug wires, life span? [Re: CMcAllister] #2113362
07/19/16 03:42 PM
07/19/16 03:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
This is the way I look at it also. Wires are a ware item just like plugs and oil. I have a few sets laying around that will work ok on street stuff.
Re: Plug wires, life span? [Re: gregsdart] #2113560
07/19/16 08:49 PM
07/19/16 08:49 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
They need to be Hipot tested, its done by a Megger. that is what is used to test the leakage and breakdown of the wire. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Plug wires, life span? [Re: gregsdart] #2113679
07/19/16 11:17 PM
07/19/16 11:17 PM
jersey
Spaceman Spiff Offline
jersey
i have a friend that had as big block and turbo in his 80 Camaro. he had a miss he couldn't find.
took the wires off ( msd) and they checked out ok, so he didn't replace them. after spending a lot of money chasing his tail, another friend asked him, when he was checking the wires, did he just checked them holding them straight, or did he bend them as he tested them.....
turns out 5 of the wires went open if he checked them while bending them, just like the would be on the car. replaced them, and the miss went away.
but i would also say, that high compression, boost, and nitrous take their toll on wires.
on a NA engine the wires would live longer.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
