Would you run this for PV clearance
#2112931
07/18/16 11:54 PM
07/18/16 11:54 PM
Posts: 1,030 ohio
67mprfan
ohio
The red is the intake and the blue is the exhaust
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Would you run this for PV clearance
[Re: justinp61]
#2112948
07/19/16 12:07 AM
07/19/16 12:07 AM
Posts: 1,030 ohio
67mprfan
ohio
I was never good at reading this type of caliper and I can always get great help on this site so I like to double check myself
[Re: 67mprfan]
#2112951
07/19/16 12:08 AM
07/19/16 12:08 AM
Posts: 1,505 TN
SCATPACK 1
TN
It looks like you are measuring in the wrong place. Measure the red clay at the thinnest point where the edge of the valve compresses the clay.
Old Geezer Racing
[Re: VernMotor]
#2112952
07/19/16 12:09 AM
07/19/16 12:09 AM
Posts: 1,030 ohio
67mprfan
ohio
Heck you could drive a truck though there !! I have always went by .100 exhaust and .080 intake Makes me wish I had a bigger cam now
[Re: 67mprfan]
#2113006
07/19/16 01:35 AM
07/19/16 01:35 AM
Posts: 43,295 Bend,OR USA
Cab_Burge
I quit measuring V to P with a dial indicactor after .120 on both valves, that is plenty Have you checked, degree, the cam yet? If not do that first and then recheck your valve to piston clearances and please let us know the differences, If any are found
[Re: 67mprfan]
#2113057
07/19/16 07:04 AM
07/19/16 07:04 AM
Posts: 1,030 ohio
67mprfan
ohio
Yes Cab this is after the cam was degreed
[Re: 67mprfan]
#2113063
07/19/16 08:28 AM
07/19/16 08:28 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Or taller pistons
i measure my clearence on the piston, slicing into the clay if neccessary if i'm being extra vigilant.
[Re: SCATPACK 1]
#2113198
07/19/16 12:21 PM
07/19/16 12:21 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
It looks like you are measuring in the wrong place. Measure the red clay at the thinnest point where the edge of the valve compresses the clay. Agreed, Unless I am seeing it wrong, shouldn't you be measuring here:
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: SCATPACK 1]
#2113253
07/19/16 01:30 PM
07/19/16 01:30 PM
Posts: 3,916 usa
lewtot184
usa
It looks like you are measuring in the wrong place. Measure the red clay at the thinnest point where the edge of the valve compresses the clay. this is what i was thinking.
[Re: 67mprfan]
#2113346
07/19/16 03:21 PM
07/19/16 03:21 PM
fast68plymouth
So. Burlington, Vt.
IMO, the clay method isn't accurate enough if the v/p clearance is questionably close. Using a checking spring with an indicator on the retainer is really the only way to know what you really have.
The only thing I use the clay for is checking the radial clearance.
[Re: Cab_Burge]
#2113626
07/19/16 10:08 PM
07/19/16 10:08 PM
Posts: 1,030 ohio
67mprfan
ohio
Well I thought I would double check myself today and this is before I cut it open to measure
[Re: Cab_Burge]
#2114000
07/20/16 01:11 PM
07/20/16 01:11 PM
Posts: 1,030 ohio
67mprfan
ohio
Wad that up so you can cut some 1/4 inch thick by 1/4 inch wide strips long enough to fit in both valve pockets on the pistons over towards the cylinder wall exhaust side and then rotate the motor through one complete valve cycle and use a dial caliper to measure the thickness of the clay on the pistons I use the skinny part that you see coming out the bottom of the dial calipers when you spread them open next to the clay on the piston tops and push the calipers open say around .500 and the press the body of the caliper down until the base barely hits the clay and then look at that measuremnent Let us know what you find Okay I'll have to try again because I'm was getting frustrated with so much clearance to me it's like wasted power
[Re: 67mprfan]
#2114014
07/20/16 01:18 PM
07/20/16 01:18 PM
Posts: 1,030 ohio
67mprfan
ohio
Could there be anything from keeping the valves from opening all the way I just got the heads freshen up maybe springs are not right
