Re: 5.7 Hemi overheating issue
[Re: WS68SSC]
#2112885
07/18/16 11:12 PM
07/18/16 11:12 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Did you actually use anything to measure the temp? Not sure if the factory gauge is anything useful, too many these days are not.
If you smelled coolant from the vents sounds like a heater core is leaking to me. Not a fun job.
[Re: WS68SSC]
#2113582
07/19/16 09:18 PM
07/19/16 09:18 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Failing thermostats will frequently give warnings like you saw.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2113622
07/19/16 10:00 PM
07/19/16 10:00 PM
Posts: 1,412 Central Pa
moparjim79
Central Pa
Failing thermostats will frequently give warnings like you saw. first thing I thought as well, had 3 modern mopars all do same thing. In the challenger it should only be a 15 min job
[Re: moparjim79]
#2113661
07/19/16 10:52 PM
07/19/16 10:52 PM
RapidRobert
find/fix the leak (required) then as said checking the stat would be an easy first step for the overheating. I would shoot it with a temp gun (reportedly the HF one works adequately) or try another (mech) gauge
