68 GTX window stop? #2111654
07/17/16 11:15 AM
07/17/16 11:15 AM
68gtx Offline OP
68gtx  Offline OP
What stops the window from rolling down too far. LF window rolls down very smooth but rolls up a bit hard?? All new everything. Car was a bit of a basket case so I sure I am missing what ever prevents the window rolling down too far. Picture would help. I see nothing in the service manual. Thanks Larry J
Re: 68 GTX window stop? [Re: 68gtx] #2111736
07/17/16 01:18 PM
07/17/16 01:18 PM
68gtx Offline OP
68gtx  Offline OP
Anyone??
Re: 68 GTX window stop? [Re: 68gtx] #2111820
07/17/16 03:17 PM
07/17/16 03:17 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Not sure what mechanicals are in your door...
If the stop was out or bad, your door glass would probably fall out of the regulator and not work at all..
If everything is new I would make sure you have the linkage lubed ( with a light grease ) and use some some dry powdered graphite ( not the liquid spray stuff in the can) in the channels that the glass rides in..
Could be kinda tight from being new... See if that helps..
Is your spring OK in your regulator?? It neutralizes the weight of the glass so you can roll it up....
Re: 68 GTX window stop? [Re: 68gtx] #2111828
07/17/16 03:24 PM
07/17/16 03:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
having the channel twisted slightly at the bottom can also cause binding. i can't remember whigh one but its the one that fits over the bracket mounted to the bottom of the door
Re: 68 GTX window stop? [Re: 68gtx] #2111868
07/17/16 04:13 PM
07/17/16 04:13 PM
68gtx Offline OP
68gtx  Offline OP
Thanks for the response. It goes down real free but up is a little tight in my opinion. My main concern is it appears to have no stopping point down. Something has to limit its travel I would think? I have the up stop in place and adjusted but i see nothing to limit the down travel? Thanks Larry J
Re: 68 GTX window stop? [Re: 68gtx] #2111876
07/17/16 04:33 PM
07/17/16 04:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
isn't the down stop on the regulator. as the arm travels down it eventually hits it depending on where you have it set to. i'm sorry but it's been years since i had my RR doors apart.
Re: 68 GTX window stop? [Re: 68gtx] #2111880
07/17/16 04:40 PM
07/17/16 04:40 PM
68gtx Offline OP
68gtx  Offline OP
I am not sure i will look at the left side its not together yet. Thanks LJ
Re: 68 GTX window stop? [Re: 68gtx] #2111888
07/17/16 04:50 PM
07/17/16 04:50 PM
68gtx Offline OP
68gtx  Offline OP
OK I see what limits its the travel. It is a small cam that is missing from my right regulator that is adjustable. Not sure if I will be able to buy the cam or just get a new regulator. Thanks for the replies. LJ
