383 Edelbrock RPM under 1964 Plymouth hood #2111730
07/17/16 01:10 PM
07/17/16 01:10 PM
Montana Flathead county
411Dude Offline OP
411Dude  Offline OP
Hello, Wondering if anybody has installed an RPM intake on a B engine in a 64 Plymouth. a hood/airfilter clearance question
Re: 383 Edelbrock RPM under 1964 Plymouth hood [Re: 411Dude] #2111762
07/17/16 01:59 PM
07/17/16 01:59 PM
The 426 Max Wedge motors fit with the stock crossram with both carbs and air filters, yours should fit with no problems twocents
Re: 383 Edelbrock RPM under 1964 Plymouth hood [Re: 411Dude] #2111862
07/17/16 04:04 PM
07/17/16 04:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Done that a couple times: RB with an RPM, Holley on a GM heat baffle & 3" open-element air cleaner. Both times though I used a drop-base aircleaner bottom.
Re: 383 Edelbrock RPM under 1964 Plymouth hood [Re: 411Dude] #2112794
07/18/16 09:51 PM
07/18/16 09:51 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My buddy has one on his 64 383 Belvedere. Pretty sure it's a regular base aftermarket air filter and it fits under the stock hood.
Zoom in if you can on the pic.
Edit: Looks like you can see it the way it is.
Kevin
Re: 383 Edelbrock RPM under 1964 Plymouth hood [Re: 411Dude] #2112920
07/18/16 11:48 PM
07/18/16 11:48 PM
New York
rarefish Offline
rarefish  Offline
New York
I have a RPM on my 64 Belvedere with a 440 and ended up having to install a drop base air cleaner with a 2-1/2" filter to get the hood to close. The RPM is a pretty tall intake.
