275/60/15 on 69 GTX - what wheel size? #211131
02/01/09 06:38 PM
02/01/09 06:38 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I am planning to run the standard 275/60/15 on the rear of my GTX. What rim size would be best? 15x8 with 4.5 bs or 15x10 with 5.5 bs. Will a 10 inch rim make the tire look wider? Any pics would be great.
Thanks,
Steve
Re: 275/60/15 on 69 GTX - what wheel size? [Re: srunge55] #211132
02/01/09 06:47 PM
02/01/09 06:47 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
You can do a quick and simple plumb bob measurement from the leaf spring inside edge, the inner wheel house and the rim mounting surface.
The spring and wheel house will tell you the max width and the wheel mounting surface will tell you the backspace.
I just make marks on the floor and then measure with a ruller.
Most all tire manufacturer's have a chart listing the best rim width for their tire sizes. You can find them on the web.
You need to leave a minimum of 1/2" on both sides of the tires for clearance.
Re: 275/60/15 on 69 GTX - what wheel size? [Re: Lefty] #211133
02/01/09 07:28 PM
02/01/09 07:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run that tire size on 15x7 but they do bulge noticeably. 10" wide rims would make the tire look wider.
Re: 275/60/15 on 69 GTX - what wheel size? [Re: srunge55] #211134
02/02/09 12:20 AM
02/02/09 12:20 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
i would go with the 15x8 with 4.1/2 bs this looks really good on b-bodys 10s might have a space issue with the inner well.
Re: 275/60/15 on 69 GTX - what wheel size? [Re: srunge55] #211135
02/02/09 02:24 AM
02/02/09 02:24 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
15 X 10 5.5 BS.
Re: 275/60/15 on 69 GTX - what wheel size? [Re: HUSTLESTUFF] #211136
02/02/09 02:25 AM
02/02/09 02:25 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
15 X 10 5.5 BS.
Re: 275/60/15 on 69 GTX - what wheel size? [Re: srunge55] #211137
02/02/09 10:18 AM
02/02/09 10:18 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I have 15x8 2756015 w/5.5bs
1981 Dodge D150 360 auto
Re: 275/60/15 on 69 GTX - what wheel size? [Re: basketcase] #211138
02/02/09 02:48 PM
02/02/09 02:48 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Hustlestuff/Basketcase,
How much room do you have at the leaf springs with the 5.5 bs?
Thanks for the replies,
Steve
Re: 275/60/15 on 69 GTX - what wheel size? [Re: srunge55] #211139
02/04/09 12:53 PM
02/04/09 12:53 PM
Cincinnati, OH
68red440 Offline
68red440  Offline
Cincinnati, OH
I have them on 15x8's with 4.5 bs. It gave me 1/2" - 3/4" gap between the tire and springs.
-Eric
Re: 275/60/15 on 69 GTX - what wheel size? [Re: srunge55] #211140
02/04/09 03:13 PM
02/04/09 03:13 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Thanks,
Steve
Steve,
The 295/50/15 looks about the best on a "8 wide
wheel.
If you must run the 275/60/15, a 8" / 4 1/2" back
space works the best
Snap your neck, mega G-force launch, is all I want!
Re: 275/60/15 on 69 GTX - what wheel size? [Re: BDS871Cuda] #211141
02/07/09 11:01 PM
02/07/09 11:01 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
My 69 GTX runs 270/60/15s on 15x8's with 4.5 bs - Priceless
Re: 275/60/15 on 69 GTX - what wheel size? [Re: moparcanuk] #211142
02/07/09 11:57 PM
02/07/09 11:57 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Are the rear wheel wells in the 68-70 cars larger than the 66-67 cars?
Re: 275/60/15 on 69 GTX - what wheel size? [Re: minivan] #211143
02/08/09 02:58 AM
02/08/09 02:58 AM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
15X8 on 275/60/15s with 5.5 bs and room to spare
Im pretty sure they are; I had a 67 Coronet a while back and it seems like I can get more tire in the 68; if for no other reason the opening is bigger
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: 275/60/15 on 69 GTX - what wheel size? [Re: RangerDan440] #211144
02/08/09 02:24 PM
02/08/09 02:24 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Thanks Dan, I assume they are by just reading the posts on tire sizes here.. anyone else?
Re: 275/60/15 on 69 GTX - what wheel size? [Re: minivan] #211145
02/08/09 03:14 PM
02/08/09 03:14 PM
Iowa
73ChargerSE440 Offline
Iowa
I have 275/60/15 on 15X7 5.5bs and 1-1½ space between wheel and leaf spring
67 Ply. Belvedere II 2dr Hardtop 73 Dodge Charger SE 440+6 727 Dana 60 4.10 78 Chrysler Cordoba 400-4 727 9 1/4 3.21 1999 Dodge Diesel 2500 QuadCab Longbox 2004 Dodge Durango HEMI Limited
