Need help finding a gremlin #2110967
07/16/16 03:02 AM
07/16/16 03:02 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
Ok I have been fighting an issue with what feels like the car is running out of fuel at wot, sounded sick running down track and popped once out of the exhaust
Verified 6 psi all the way down track
jetted up 2 sizes from 84 Sq to 86 Sq (car ran best et @84)
timing at 34*
had the heads re done springs checked good
all filters clear, psi on pump verified with visual into a tank
I am down 3 MPH in the 8th and 2 in the quarter
thinking it has to be in the distr. or box or coil
running msd distr, firecore wires, msd coil and a msd 6Al box grounded to the batt. alter is showing 14 volts
best today was a 10.447 @128.98, 1/4 6.642 @ 103.25 1/8th
best ET is in sig
Help me find the gremlin
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2110968
07/16/16 03:05 AM
07/16/16 03:05 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
strip the carb, blow out all the air bleeds & fuel holes, reassemble & try again.
Re: Need help fiding a gremlin [Re: rebel] #2110977
07/16/16 03:35 AM
07/16/16 03:35 AM
pacific northwest
pacific northwest
done that, did the same thing with a different carb too
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111012
07/16/16 09:28 AM
07/16/16 09:28 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A pop out of the exhaust would tell me fuel is in the pipes. Look at the ignition system.
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111020
07/16/16 10:06 AM
07/16/16 10:06 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Is the positive wired direct to the batt? My 6al die competely last summer(no spark). Before it die, the car just wasn't running right,
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111033
07/16/16 10:38 AM
07/16/16 10:38 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
If the carb has high speed air bleeds they might be too small? Had similar problem adjusted air bleeds and fixed the problem on the dominator.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111036
07/16/16 10:48 AM
07/16/16 10:48 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Could be msd box, or maybe valve float. Check spring pressure lately?
[image][/image]
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111050
07/16/16 11:27 AM
07/16/16 11:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
See if a buddy has a MSD box you can try... I
had a high end miss that you could barely hear
and I did a A-B-A test with the box.. it was a box
issue.. sent it in to MSD for a rebuild.. they said
it was fine.. when I got it back it worked great...
but I know the box was the cause(A-B-A) test proved that
then try another coil
wave
Re: Need help fiding a gremlin [Re: MR_P_BODY] #2111051
07/16/16 11:30 AM
07/16/16 11:30 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
If it has a RPM chip in it, run it without it. If the problem goes away the chip is bad.
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111053
07/16/16 11:32 AM
07/16/16 11:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Tug on the wiring where it is crimped and see if any wires pull out of the terminals.
Doug
Re: Need help fiding a gremlin [Re: fbs63] #2111078
07/16/16 12:02 PM
07/16/16 12:02 PM
tboomer Offline
tboomer  Offline
[quote=fbs63]If it has a RPM chip in it, run it without it. If the problem goes away the chip is bad. [/quote
This is worth a try. I had it happen to my 64.
Re: Need help fiding a gremlin [Re: tboomer] #2111083
07/16/16 12:06 PM
07/16/16 12:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep.. worth a try.. its simple... I've had a few that
would change.. they would start dropping out a good 500
rpms below what they were set for... just pull all the
chips and try it
wave
Re: Need help fiding a gremlin [Re: MR_P_BODY] #2111098
07/16/16 12:29 PM
07/16/16 12:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
THIS............Was testing a friends Torino at night before a race and same thing, popping way before the redline so I suggested removing the chip and problem gone..........Not to say this is your problem but start w/the simple ones first........
Re: Need help fiding a gremlin [Re: Thumperdart] #2111116
07/16/16 01:17 PM
07/16/16 01:17 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Had a bad shift light that did the same thing..
Re: Need help fiding a gremlin [Re: 70dusterjohn] #2111124
07/16/16 01:38 PM
07/16/16 01:38 PM
if the chip dont do it what about subbing in a spare regular electronic dist/ECU for a test? it'd be a bit of doing but it'd cut right to the chase by getting the Might/Sputter & Die system out of there
Re: Need help fiding a gremlin [Re: RapidRobert] #2111164
07/16/16 02:52 PM
07/16/16 02:52 PM
pacific northwest
pacific northwest
RPM chip has already been removed
have a line on another box and coil to try
Valve springs checked good
I will let you know what I find
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111198
07/16/16 04:18 PM
07/16/16 04:18 PM
crabman173
crabman173
Those kinds issues almost always ignition---MSD distributors use an odd metal for the reluctor--it does corrode fast--we spray new units with WD40 and blow off before install--check it first--I have seen them where you take cap off and it looks like a piece of iron that came from bottom of the sea--first thing I check when trouble comes--if you have real 12 volts to fuel pump it is usually not the issue--a "fill the can" test is best way to check fuel system --if carbs don't have trash they don't change all of a sudden--clean filters, can fill test, voltage test , check grounds but check MSD reluctor First--if that is good throw the coil in the ebay pile and get a new one
Re: Need help fiding a gremlin [Re: rickraw] #2111423
07/16/16 10:56 PM
07/16/16 10:56 PM
pacific northwest
pacific northwest
Pos. is wired to the starter and has been that way since day one
Re: Need help fiding a gremlin [Re: ] #2111424
07/16/16 10:58 PM
07/16/16 10:58 PM
pacific northwest
pacific northwest
I had the distr. out and all cleaned up it was pretty rusty
Re: Need help fiding a gremlin [Re: Stroker Scamp] #2111757
07/17/16 01:49 PM
07/17/16 01:49 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I chased a burble at the stripe. Turned out to be the exposed part of the #2 exhaust guide in the combustion chamber disappeared. Evidently, there wasn't enough material to allow it to seat concentrically. Spring pressure was good. New guide, problem solved. I now have a complete spare MSD ignition system. hammer
