Re: Hellcat Block Pictures
[Re: hudsonhornet7x]
#2252631
02/12/17 10:59 PM
02/12/17 10:59 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Really not much point doing a regular small block Mopar if you are starting from scratch, just need to figure out what heads to use.
A new iron curtain drawn across the 49th parallel
[Re: Dadodgekid]
#2254734
02/16/17 08:51 PM
02/16/17 08:51 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
426ci hellcat block seems rather enticing! with the newer blocks, could you use the 32tooth reluctor cranks and older style cams to get away from the VVT and go with an MSD6 CDI? I try and keep it simple... Yes on the reluctor wheel , NO on the cam. But all you need to do with the stock cam is lock it out. Comp cams has a kit.
[Re: dogdays]
#2254998
02/17/17 01:27 PM
02/17/17 01:27 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Yeah, makes it really hard on those of us with a mountain of obsolete LA stuff. Now I'm two generations behind, first the Mag and now the Hemi.
R. Ha! I've yet to build a stout small block anything... I'm still in Purple Shaft land... At that price, wow. It's hard not to justify doing Gen 3 over LA or big block stuff...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
#2255005
02/17/17 01:43 PM
02/17/17 01:43 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Been Gen III Hemi for almost 3 yrs. No regrets, wanted a high powered reliable, efficient, pump gas engine and it is that in spades.
Mopar to the bone!!!
[Re: JandJ_Racing]
#2504637
06/05/18 01:42 AM
06/05/18 01:42 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Anyone working with the 6.2 block yet? Curious about using a 5.7 cam core?
Brian Hafliger
#2504825
06/05/18 02:21 PM
06/05/18 02:21 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have one and the cams look identicle in fitment dimentions
#2504828
06/05/18 02:27 PM
06/05/18 02:27 PM
HotRodDave
Kalispell Mt.
I think the 5.7 cam may be better to start with as the base circle is not ground down as low.
Anyone care to elaborate on the supposed machining difference in the BGE and hellcat? I dont see any...
#2504890
06/05/18 04:26 PM
06/05/18 04:26 PM
HotRodDave
Kalispell Mt.
I got mine used for $300 off the line.
