can you paint a car useing oxygen tanks *DELETED*
#211047
02/01/09 05:51 PM
02/01/09 05:51 PM
Posts: 363 Canada
westfort
Canada
Re: can you paint a car useing oxygen tanks
[Re: westfort]
#211048
02/01/09 05:53 PM
02/01/09 05:53 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
just wondering if anyone has tried useing oxygen tanks as a source of clean air to paint a car wondering if it would be a sure way yo prevent contaminats al
My God that would be dangerous!
[Re: westfort]
#211049
02/01/09 05:54 PM
02/01/09 05:54 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
While you may be able to get the gun to work with it, think about what you are doing, spraying an atomized flamable substance (paint, thinners, etc...) with pure oxygen; this is a recipe for distaster...
Now, nitrogen or some inert gas may work, but with modern HVLP guns you need so much air it is not practical for anything but a small job.
[Re: GoDartGo]
#211052
02/01/09 07:35 PM
02/01/09 07:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pure oxygen and oil are an explosive mix. Bad idea.
[Re: westfort]
#211053
02/01/09 08:31 PM
02/01/09 08:31 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
If they have, they probably aren't around anymore to tell us how it worked.
As mentioned, this is not a good idea. Please do not try it.
[Re: belv2vert66]
#211059
02/01/09 11:24 PM
02/01/09 11:24 PM
Seriously, with no ignition source, why would it be any more dangerous ? So assuming you eliminate any source of ignition. I would guess you would run out of air......I guess a better situation than when scuba diving, but paint is expensive......
Are you joking, son? Oxygen can be one of the most dangerous gases on the planet in pure form, mostly because people "don't think" Pure oxygen causes ANY possible combustible mixture situation to be more dangerous, because it's more concentrated. ANY oxygen added to any flame instantly causes a massive flare-up and accellerated burning.
Oxygen can self ignite with some substances-- (spontaneous) which is why you NEVER use oxygen around oil, or allow it in the fittings or hoses, etc.
When you have time, look up our NASA history, the incident where a spacecraft burned during a ground test. Part of that problem is that they were using a PURE OXYGEN atmosphere, and some spark.....somewhere......
http://history.nasa.gov/Apollo204/
#211060
02/01/09 11:42 PM
02/01/09 11:42 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
why not try it with hydrogen instead.. actully you could use compressed air..lots of welding supply company have it, its used in the air craft industry..
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
#211062
02/01/09 11:48 PM
02/01/09 11:48 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Maybe if you paint out side you might be ok, years ago i seen a guy use 20lb. propane tanks to spray a car, and yes they were filled with propane. It was outside and yes we did think he was crazy, actually he did two more that i know of and the job was not bad. He did die at a early age, years after the propane deals, i don't think our suppose to breath propane.
[Re: rowin4]
#211063
02/02/09 09:34 AM
02/02/09 09:34 AM
Posts: 8,874 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Oh, yeah sure, that'll help !!!!! Notice he's saying "maybe" and "might" here, meaning he really doesn't know. Just the sort of advice you need in a life threatening situation.
[Re: Stanton]
#211064
02/02/09 10:08 AM
02/02/09 10:08 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
sure, in a perfect world, you can eliminate all spark sources, and paint with straith O2 as your propelant. Wake up man! ever hear of STATIC ELECTRICITY? all it takes is 1 spark from static and BOOM! all it takes is one spark from something plugged into the wall, a light bulb in your shop to blow, trip a breaker on your circuit panel, heck, even flipping a switch can create a spark as electricity jumps the gap just before the switch makes contact.
don't use O2. now, if you meant SCUBA gear, then that's fine. SCUBA is just straight air, 78% Nitrogen, 20% Oxygen and the rest is junk--CO2, and other miscelaneous stuff. SCUBA gear is no different than what your air compressor would be putting out.
Perhaps that's what you meant, and mistakenlly called it "O2 tanks" which is pure O2, typically only found onboard aircraft, and in medical applications. and in some cases, SCUBA when the diver plans on doing a deep dive and wants to denitrogenate themselves so that when they come back up, the nitrogen won't boil out of their blood as they depressurize from the depths.
**Photobucket sucks**
[Re: westfort]
#211065
02/02/09 11:57 AM
02/02/09 11:57 AM
Posts: 2,592 None
71rm23
None
NOT ME
