Re: Narrowed 8 1/4 with 8 3/4 axle
[Re: convx4]
#2110778
07/15/16 08:43 PM
07/15/16 08:43 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
I have a big bolt pattern 7.25 you can have if you want to come to my shop in Milford and get it.
[Re: convx4]
#2110894
07/15/16 11:56 PM
07/15/16 11:56 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I acquired a free 9.25" 3.55 geared truck rear just a few days ago. I am going to stick it in the back of my shop while I decide what to do with it. I already built a Dana 60-2 to fit my truck, but when I built it I should have gone with the Ford "Torino" bearings and used a new set of the Ford 11" drum brakes (I could have had those in 5 on 5.5" or 5 on 4.5" patterns) like I did for the Ramcharger. If I put the Dana 60-2 in the D100 like I originally planned, I will have to shorten the driveshaft 1.12" and if I use the 9.25" rear, I won't have to shorten it at all, because the axle C/L distance is the same as the existing 8.25".
If I had a lathe there is no telling what neat stuff I could make.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: convx4]
#2110965
07/16/16 02:47 AM
07/16/16 02:47 AM
RapidRobert
Hell if I could easily convert the 7 1/4 to big bolt I would do that instead. A slant six is its power house. there are BBP 7&1/4's (likely 73-76 A body with discs). there's even sure grips (cone & clutch) I have a 3:55 clutch SBP (early) 7&1/4. I wonder (in your case) if the SG could be transplanted into a later BBP 7&1/4. they are pretty rare tho. SBP/BBP 7&1/4 axles them selves do not interchange
[Re: convx4]
#2111218
07/16/16 05:11 PM
07/16/16 05:11 PM
slantzilla
Park Forest, IL
Slantzilla, is it an A-body? It looks like your less than 5 hour drive one way. Any chance you'll be in St Louis any time in the future? No, I don't get that way often. Yes, it is out of a Duster.
[Re: convx4]
#2111541
07/17/16 03:25 AM
07/17/16 03:25 AM
slantzilla
Park Forest, IL
Do an 8.8 out of an Exploder. They are a pretty easy swap, and have disc brakes already.
[Re: convx4]
#2112738
07/18/16 08:41 PM
07/18/16 08:41 PM
slantzilla
Park Forest, IL
I think Jeeps used rear disc, the last Gen 3 Dakota R/Ts did too.
