Spark plugs. #2109963
07/14/16 03:41 PM
07/14/16 03:41 PM
Oslo
Cuda 1968 Offline OP
Oslo
What kind of spark plugs would you recommend in a 472 Hemi with aluminum heads, 11.5 compression and a mild mechanical cam.
Thanks.
TAS.
Re: Spark plugs. [Re: Cuda 1968] #2110059
07/14/16 06:43 PM
07/14/16 06:43 PM
What's the quality of the local fuel you will be using in it? Which brand of spark plugs do you like to use? If Champions I would try a RC9YC or RN9YC and if that looks like it is to hot try a RN6YC or a RC6YC. If you like Autolites try a AR3911 or the colder AR3910 scope twocents
BTW, is that compression ratio actual measured or maybe correct confusedworkIf it is the actual ratio those plugs should be in the ball park thumbs If it is lower than that then you might want to use a hotter plug work It is a lot safer to use a colder plug when in doubt so be safe thumbs
Re: Spark plugs. [Re: Cuda 1968] #2110070
07/14/16 07:02 PM
07/14/16 07:02 PM
an8sec70cuda Offline
NGK 4554 (R5671A-8)
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spark plugs. [Re: Cuda 1968] #2110243
07/14/16 11:57 PM
07/14/16 11:57 PM
crabman173
crabman173
Call the NGK tech Hotline--Best tech available from any company--they put you dead on! Chip I run an 8 in a 13.7:1 think maybe a little cold for that app but...Trust in the Force and the NGK tech line!!!!!!!!
Re: Spark plugs. [Re: ] #2110585
07/15/16 04:16 PM
07/15/16 04:16 PM
Oslo
Oslo
Thanks for your advice, it will get me in the right direction.
TAS.
Re: Spark plugs. [Re: Cuda 1968] #2110593
07/15/16 04:26 PM
07/15/16 04:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I would think an NGK# 7 would work well...........
Re: Spark plugs. [Re: Cuda 1968] #2110596
07/15/16 04:35 PM
07/15/16 04:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run NGKs in my 12.5 440 with aluminum heads.Just changed them after 5 years.They were still running great juts did as maintaince.We run them in almost everything.We ran a lot of them at the shop also when I was working.Rocky
Chrysler Firepower
