Any Turbo R3 48 degree combos out there??
#2109447
07/13/16 04:43 PM
07/13/16 04:43 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Hey everyone, long time no post. I am looking to start collecting parts to go forced induction, most likely twin turbo on my R3 48 degree. I have heard (Haven't phoned around yet as I am not ready to order right now) that finding a cam core that will go to the desired LSA I am looking for may be tough. Our last 48 degree deal we did was this year, and I think it was Cam Motion or else Bullet had the cores, but it was an NA deal.
Anyone heard of where some cores may be?
rough plan is to de-stroke my current combo to about 440ci. I will probably go to my W9 top end at the same time, and so far, I am happy with borg warner turbos on my other builds. I was thinking a pair of S475's with an 83mm turbine on the exhaust. Not totally sure on AR, but probably 1.10. These would be t4 housings as well. Most likely I would go with MS3 Pro at this point in time, and a 2 speed of some sort. Like I said, it's a rough idea at this point. I am currently still finishing up my new street truck project, a 408ci LS with a billet borg warner S476 T6 with a 96mm turbine and 1.32 AR. The truck will take over more of the street duty, and I will move the Aspen more to a race car with mufflers and a license plate.
Thanks!
-Kenny
Re: Any Turbo R3 48 degree combos out there??
[Re: rpagan]
#2109646
07/13/16 10:35 PM
07/13/16 10:35 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
If you go 55mm comp will make you whatever you want . And it's fairly reasonable. I thought you were running a ritter block.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2109880
07/14/16 01:03 PM
07/14/16 01:03 PM
StrokerAspen
Alberta Canada
Thanks guys, I will look into those sources. If you go 55mm comp will make you whatever you want . And it's fairly reasonable. I thought you were running a ritter block. The Ritter block was a customers engine. I have ran a 673AD R3 for the past 4 or 5 years now I think. -Kenny
[Re: StrokerAspen]
#2110915
07/16/16 12:21 AM
07/16/16 12:21 AM
Posts: 3,505 DFW
mr_340
DFW
I know of a complete R3/W8 engine setup ready to run in the Tampa area. CFE W8 heads and intake, .900" roller cam, no turbos, est. 2400 HP. Was built for a customer going to run it in a drag race Viper, customer backed out of the deal for financial reasons. PM me if you are interested.
Floyd Lippencott IV
[Re: StrokerAspen]
#2111108
07/16/16 01:03 PM
07/16/16 01:03 PM
Posts: 70 Finland
mopar396
Finland
I have R3 48 deg w8 heads. 3.58 crank 6" rods 4.08 diamond pistons 11cr. cam is SMRE but that was designed for procharger. Bw s480 turbos holley dominator efi with methanol Powerglide trans Best so far in 1/4 is 6.90@199.5 https://www.youtube.com/watch?v=KSTVR8orXSQ
MOPAR OR NO CAR
