Driveline angle #2109596
07/13/16 08:54 PM
07/13/16 08:54 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
Measured angle of transmission down 3.5 degree pinion is 1.5 degree down drive shaft is 3.5 down. Is this close? Thanks Bradley
Re: Driveline angle [Re: roadrunnerreds] #2109631
07/13/16 10:03 PM
07/13/16 10:03 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Not sure I understand correctly. It seems your transmission and driveshaft are perfectly in line, but is the pinion 1.5 down from that angle or 1.5 from straight, meaning a 2 degree difference between the shaft and pinion. I think the pinion being 1-2 down from shaft angle is acceptable. It will nose up slightly under load. If it is 2 up from driveshaft, you have to lower the pinion angle.
[image][/image]
Re: Driveline angle [Re: roadrunnerreds] #2109647
07/13/16 10:35 PM
07/13/16 10:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Driveshaft down 3.5 front to rear? Pinion nose down 1.5 at the yoke? If so, that's 5 degrees negative. Pinion down 1.5 front to rear? That's 2 degrees negative.
popcorn
Re: Driveline angle [Re: roadrunnerreds] #2109657
07/13/16 10:53 PM
07/13/16 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What rear suspension... but think of it this
way.. if the trans is pointed down 3.5 and if
the diff was pointed up 3.5 that would be zero
then roll the nose down for what you need
wave
Re: Driveline angle [Re: CMcAllister] #2109661
07/13/16 11:09 PM
07/13/16 11:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I too see 5* negative neglecting drive shaft angles...........
Re: Driveline angle [Re: roadrunnerreds] #2109671
07/13/16 11:22 PM
07/13/16 11:22 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Master, again and still
Re: Driveline angle [Re: roadrunnerreds] #2109673
07/13/16 11:24 PM
07/13/16 11:24 PM
Gettysburg Pa
Gettysburg Pa
It is ladder bars with dana 60 trany is 3.5 degrees down. Rearend is down 1.5 degrees
Re: Driveline angle [Re: roadrunnerreds] #2109676
07/13/16 11:30 PM
07/13/16 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your at 5*.. with a ladder bar you want 1* - 2*
wave
Re: Driveline angle [Re: roadrunnerreds] #2109687
07/13/16 11:49 PM
07/13/16 11:49 PM
Gettysburg Pa
Gettysburg Pa
I adjusted to +.5 degrees at pinion. Is that ok? ThanksBradley
Re: Driveline angle [Re: roadrunnerreds] #2109689
07/13/16 11:51 PM
07/13/16 11:51 PM
Gettysburg Pa
Gettysburg Pa
Early abody so limited at shimming trany
Re: Driveline angle [Re: roadrunnerreds] #2109692
07/13/16 11:54 PM
07/13/16 11:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.5 from what.. what the trans is
EDIT
Set it at 2* pointed up.. that will give you
1.5*
wave
Re: Driveline angle [Re: roadrunnerreds] #2109694
07/13/16 11:57 PM
07/13/16 11:57 PM
Gettysburg Pa
Gettysburg Pa
From rearend in ladderbars pinion is now +.5 up
Re: Driveline angle [Re: roadrunnerreds] #2109695
07/14/16 12:01 AM
07/14/16 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I edited my post above.. look there
wave
Re: Driveline angle [Re: roadrunnerreds] #2109697
07/14/16 12:04 AM
07/14/16 12:04 AM
Gettysburg Pa
Gettysburg Pa
Rear was 1.5 down
Re: Driveline angle [Re: roadrunnerreds] #2109702
07/14/16 12:11 AM
07/14/16 12:11 AM
Gettysburg Pa
Gettysburg Pa
Thanks been fighting a rumble in car. I have a weight on end of tail housing. 904 trans
Re: Driveline angle [Re: roadrunnerreds] #2109707
07/14/16 12:16 AM
07/14/16 12:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That factory weight... if this is a race car you dont
need that weight... it was for a factory issue that
caused the steering wheel to vibrate some...
all they did with that weight was change the
frequency to another point
wave
Re: Driveline angle [Re: roadrunnerreds] #2109738
07/14/16 01:08 AM
07/14/16 01:08 AM
Gettysburg Pa
Gettysburg Pa
Should it be smooth if i run it on jack stands. I have them under rear axle and front suspension.
Re: Driveline angle [Re: roadrunnerreds] #2109741
07/14/16 01:14 AM
07/14/16 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Should if the tires are balanced... did you get the
pinion up to 2*
wave
Re: Driveline angle [Re: roadrunnerreds] #2109879
07/14/16 01:01 PM
07/14/16 01:01 PM
Gettysburg Pa
Gettysburg Pa
Yes and took weight off tail housing. Seems better
Re: Driveline angle [Re: roadrunnerreds] #2109885
07/14/16 01:07 PM
07/14/16 01:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are the U-joints in good shape and is the drive
shaft straight and balanced
wave
