Re: 67 to 69 fiberglass barracuda doors
[Re: cudaman1969]
#2110257
07/15/16 12:07 AM
07/15/16 12:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
So what did your door weigh on the scale fully assembled ? I got confused with the other statement . Sorry, 92 to 93 pounds that's with a complete door and hinges, just as it came off car. Door with nothing on it, 37 pounds. Just a bathroom scale. Still 55 pounds of stuff on door wow 92lb each 184 total .fiberglass replacement doors 20lb each 40 pounds total..savings 144lb.. is this correct. No, 110 pounds of glass, hinges, handles,vent windows, window mechanisms, latch, door panels, arm rests or everything that goes on the door. But I doubt any of that can be bolted on a fiberglass door. 20 lb fiberglass door verses a 37 lb steel door, you save 17 lbs each door, maybe. What happened to the 12# door... now it grew to 20#
[Re: fishy340]
#2110755
07/15/16 08:14 PM
07/15/16 08:14 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
92 or 93lbs give or take to 16 or 17lbs fully dressed would make me happy...:)
BTW my Dash came from Glasstek in less than 4 weeks and it's Mint. What? Are you gonna use fiberglass doors with no glass, hinges or latch?
