Rear wheels under power in Neutral 727 trans. #2109446
07/13/16 04:42 PM
07/13/16 04:42 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Changed a leaky trans gasket on my 69 GTX.Now the rear wheels are engaged in neutral.All linkage looks fine you can feel it move from gear to gear.Its fine in park.I didn't touch anything else.Any ideas?
Re: Rear wheels under power in Neutral 727 trans. [Re: gts1] #2109473
07/13/16 05:20 PM
07/13/16 05:20 PM
Chicago
PurpleBeeper Offline
Chicago
"somehow" you bumped the shifter linkage out of adjustment.... if the wheels are moving, it's not in neutral. Will the wheels stop turning if you put the shifter between gears....a little more forward or a little more back?
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Rear wheels under power in Neutral 727 trans. [Re: gts1] #2109515
07/13/16 06:14 PM
07/13/16 06:14 PM
an8sec70cuda Offline
Did it do this before? Or did you never notice it before?
A tight clutch pack in the trans will cause the tires to turn in neutral. It won't move like it's in first gear or anything, but it will move slightly. If the car is on jackstands, the wheels can move enough for you to think it's in gear.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rear wheels under power in Neutral 727 trans. [Re: an8sec70cuda] #2109598
07/13/16 08:55 PM
07/13/16 08:55 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Yep , at least one of my cars does this when in neutral on jackstands. Turns at a pretty good speed too.
Re: Rear wheels under power in Neutral 727 trans. [Re: gts1] #2109600
07/13/16 09:07 PM
07/13/16 09:07 PM
WA
tman Offline
tman  Offline
WA
Same here. When its on the ground, it doesn't move.
Re: Rear wheels under power in Neutral 727 trans. [Re: gts1] #2109603
07/13/16 09:16 PM
07/13/16 09:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Fluid flow friction causing it. Setting it back on the ground will stop it.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Rear wheels under power in Neutral 727 trans. [Re: gts1] #2109604
07/13/16 09:17 PM
07/13/16 09:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How are you determining the wheels are engaged in neutral?
Does it take off down the road ?
Re: Rear wheels under power in Neutral 727 trans. [Re: tman] #2109607
07/13/16 09:21 PM
07/13/16 09:21 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
I put it down & it appears to be fine.It was up on jackstands but it was definitely moving under power I tried to stop the tires with a long 2x4 & couldn't.
Re: Rear wheels under power in Neutral 727 trans. [Re: gts1] #2109615
07/13/16 09:32 PM
07/13/16 09:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you put it down on the ground and it's not moving then you didn't try hard enough or your engine is idling at too high an RPM. I have stopped the tires from moving with my foot against the side of the tire.
The tires are moving because of parasitic drag of the fluid between the clutches and steels, the fact that it doesn't drive away when you put it on the ground tells you it's a non issue ... unless you try to make it an issue and injure yourself ...
