Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109431
07/13/16 04:04 PM
07/13/16 04:04 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i didn't know people used ridge reamers anymore.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109434
07/13/16 04:10 PM
07/13/16 04:10 PM
IL
furious70 Offline
furious70  Offline
IL
seems like buying a used bottle kit and strapping it in is your best bet based on all the parameters.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109440
07/13/16 04:32 PM
07/13/16 04:32 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Ebay Turbo!!!
Re: Upping the Comp ratio on a 400, engine builders please [Re: lewtot184] #2109517
07/13/16 06:20 PM
07/13/16 06:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its a OLD block.. they were soft(before they
started putting more nickle in them) you HAD to
use a ridge reamer to even get the piston out of
the bore.. yeah I still own one somewhere around
here but havent used it in over 20 years(maybe 25)
wave
Re: Upping the Comp ratio on a 400, engine builders please [Re: MR_P_BODY] #2109602
07/13/16 09:16 PM
07/13/16 09:16 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
wave
i remember them from back in the day. folks breaking pistons trying to push them thru the ridge,..lol. used to be able to rent thru the mail. i just thought things have progressd to a point to where they were obsolete.
i was thinking about a 360 i put together. this was 100,000 mile dakota engine. always unleaded fuel and the oil changed religiously. from what i can remember running a dial bore gauge thru the cylinders that there was next to none taper! that 400 may not have a ridge; if taken care of.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109737
07/14/16 01:08 AM
07/14/16 01:08 AM
Boise
Moparteacher Offline
Boise
If you're not boring or power honing the cylinder then ignore the recommendation to ignore using the ridge reamer and use the ridge reamer. It's not rocket science. You may be able to rent one from an auto parts store.
If the new top compression rings run up and over a ridge at the top of the cylinder, even after use of a ball or three finger glaze breaker, it will destroy the new rings and pistons. Even if you use the same piston it will destroy the rings and piston because the new bearing raises the piston height in the cylinder, even thought it's only a thousandths of an inch.
Removing the ridge isn't just for ease of piston removal.
It's easiest to use before piston removal because you can square the tool on top of the piston. It's not rocket science unless you're the guy that screwed it up for JohnRR, and the instructions are an easy read.
Re: Upping the Comp ratio on a 400, engine builders please [Re: Moparteacher] #2109746
07/14/16 01:23 AM
07/14/16 01:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mine sat on the deck so it was square to the deck
but I believe any 400 block has plenty of nickle
in it... so it might be ok
wave
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109818
07/14/16 10:22 AM
07/14/16 10:22 AM
an8sec70cuda Offline
Every block I had come into the machine shop where I worked that had a ridge reamer used on it was screwed up. Not all, but the vast majority of people will remove way too much material from the bore w/ a reamer.
I've taken a lot of motors apart that had big ridges and never used a reamer. Not worried about saving the pistons, so I just knock em out. If it has a big ridge, the pistons shouldn't be getting reused.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Upping the Comp ratio on a 400, engine builders please [Re: lewtot184] #2109822
07/14/16 10:27 AM
07/14/16 10:27 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bet the moly rings, harder block and superior efi fuel control had something to do with that.
Re: Upping the Comp ratio on a 400, engine builders please [Re: DaytonaTurbo] #2109829
07/14/16 10:55 AM
07/14/16 10:55 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
your probably right. i know leaded fuels ate up engines. as much as we curse unleaded, it does make the cylinders last longer and better oils are a plus.
Re: Upping the Comp ratio on a 400, engine builders please [Re: an8sec70cuda] #2110006
07/14/16 05:11 PM
07/14/16 05:11 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That is my thoughts also. If it has a slight ridge, take care of it when honing the block. If it has a large ridge, the bores are worn to the point where it really needs overbore and larger pistons/rings. Re-ringing a worn out bore and piston is a waste of money in my opinion.
I think some people are afraid or intimidated to take their stuff to a machine shop and get a professional opinion?
