EFI Tunnel Ram or Single
#2107686
07/11/16 01:53 AM
07/11/16 01:53 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have decided to switch over a few of my cars to EFI this year. Is a tunnel ram with duals better or single intake better for big CI Hemi (605" and 582") and wedge(493" and 500") for race cars and street cars?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: EFI Tunnel Ram or Single
[Re: 65 Hemi]
#2107726
07/11/16 04:02 AM
07/11/16 04:02 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
I would opt for the most air possible, especially on a drag race motor
[Re: 65 Hemi]
#2107803
07/11/16 11:21 AM
07/11/16 11:21 AM
Posts: 22,728 Bitopia
jcc
Bitopia
Do you have some reason thinking a single is better on an EFI TR, other then maybe cost?
[Re: 65 Hemi]
#2108591
07/12/16 11:12 AM
07/12/16 11:12 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The linkage is only part of the issue. TPS/blade relation for accel enricments can be a problem with some systems when big/ multiple TBs are used with some combos. Older TPS styles don't have the resolution of some newer stuff. I had a guys 355 inch SBC with an 871 and enderle 3 blade hat, converted to efi. It used a tps from a tuneport gm. The 3 sensors I tried were horrible with voltage "notchyness". Very difficult and finicky. I always use a cam lever or progressive linkage on stuff I set up.
[Re: TRENDZ]
#2108645
07/12/16 12:22 PM
07/12/16 12:22 PM
jcc
Bitopia
So the problem is NOT the size of the efi throttles, more the accuracy, sensitivity and calibration of the sensors, with current technology, that is the problem, correct?
[Re: 65 Hemi]
#2108679
07/12/16 01:25 PM
07/12/16 01:25 PM
TRENDZ
Milwaukee WI
With all of the modern efi control systems, the capability is there to get the programmed values perfect. If the main fuel table is set up correctly, you need "almost" no accel enrichments. The issue is getting an accurate, linear TPS. You also need to remember that that if you are using multiple throttlebodies, you still only have one TPS. This effectively cuts the tps resolution down by the multiple of throttle shafts. Now that single tps has to account for all of the throttle shafts positions. It would roughly be like using one accelerator pump cam to control the pump shot of two carbs.
[Re: 65 Hemi]
#2108708
07/12/16 02:01 PM
07/12/16 02:01 PM
TRENDZ
Milwaukee WI
Everybody likes what they like. Just sharing what I've been seeing with cars set up and "tuned" by others before being brought to me. Monte, what kind of TBs did you put on the reaper camaro? Slick looking units. Never saw the car in person, but from the TV views, I can't see how the are fastened down. They just look round with no flange.
