Spiral lox issue #2107679
07/11/16 01:48 AM
07/11/16 01:48 AM
RapidRobert Offline OP
SB KB 372 hyper pistons. what spiro loks do I need? I found some loose ones (CS25 on pkg) that when held up sideways are (2) layers thick & they seem to fit OK. I have a full set of ones that are (3) layers thick & appear to be much larger OD & will not fit. I want to go together tomorrow & not sue how long it will take me to find a partial or full set of the (2) layer ones. Can I use snap rings or are these needed? (full floater pins). Any ideas on where to get these? thank you for your time
Re: Spiral lox issue [Re: RapidRobert] #2107725
07/11/16 04:00 AM
07/11/16 04:00 AM
Call KB Silvolite(800-648-7970) tech. in the morning and ask them for the proper part number scope You can order them through Summit thumbs
Re: Spiral lox issue [Re: RapidRobert] #2107745
07/11/16 08:06 AM
07/11/16 08:06 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Spiral lox issue [Re: 70AARcuda] #2107778
07/11/16 10:33 AM
07/11/16 10:33 AM
Thanks guys! & X2 on the number clarification, Hell I could ordered locks for that wrong piston # & still been in a jam! EDIT called KB & they ain't up yet but left msg & I'm sure they will get back to me
