Pormance on my 408 #2107534
07/10/16 10:09 PM
07/10/16 10:09 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hello everyone !
I would need your comments on the performance of my Indy headed 408.
I've been quite happy with the pleasure and fun my 67 Barracuda for the past 2 years. But some questions are left unanswered concerning performance.
First, here is the set up:
67 Barracuda 3000lbs with me in ti
ladder bar with Dana 60 , 4.56 gear
5000 stall conv 904 trans, low gear set
408 cid 10.8 cr -1 heads 343 cfm int 275 exh
Mopar W2 tunnel ram with a pair of Proform main body (750cfm) and billet metering block around
My 60ft are pretty good, yesterday I made a 1.29sec 60ft with the dual quad
Last year average 60ft was 1.32sec...
Here is the problem: I run on an 1/8 mile track, and I feel et's are not what they are supposed to be....
If I had a 60ft of 1.32, et was 6.42
If I had a 60ft of 1.30, et was 6.30
If I had a 60ft of 1.34, et was 6.34 and so on....
I scratch my head and say to myself: heck with that 60 ft, I'm supposed to run faster et's !!! right ????
I feel something is wrong here......but what ???????
Yesterday, with a 60ft of 1.29, I ran 6.50 sec no power valve and 75 jets....Ok it is a new set up, needs fine tuning etc.......But still !!
What is going on here ??
I'm supposed to be faster than that !!
Need any idea you can throw....
Dan
Re: Pormance on my 408 [Re: Wedgeman] #2107548
07/10/16 10:24 PM
07/10/16 10:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You can only go as fast as the power available and those 60`s indicate a good working suspension........Not to say the carbs don`t need attention though..............
Re: Pormance on my 408 [Re: Wedgeman] #2107554
07/10/16 10:36 PM
07/10/16 10:36 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
What's ur mph?
Re: Pormance on my 408 [Re: Wedgeman] #2107563
07/10/16 11:01 PM
07/10/16 11:01 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I don't have the mph.....sorry
Re: Pormance on my 408 [Re: Wedgeman] #2107567
07/10/16 11:05 PM
07/10/16 11:05 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
MPH is definitely some needed info, did the time slip not print out correctly?
Have you had time to jet the carbs up or down or move the timing up and down?
Your 60 foot is pretty awesome.
Re: Pormance on my 408 [Re: Wedgeman] #2107572
07/10/16 11:16 PM
07/10/16 11:16 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
No mph at this track.....
No I didn't have time to play with jet or timing...
I'll try to lower my jets to 72 next week end
Re: Pormance on my 408 [Re: ProSport] #2107574
07/10/16 11:19 PM
07/10/16 11:19 PM
SoCal
Brian Hafliger Offline
SoCal
I would never run an engine with a tunnel ram without first dyno tuning it!
That said, you should be closer to 80 jets with no power valves...OOTB around 72-80 jetting with PV in front, so more like 80's square but I would try 78 jets square in both carbs first.
If it's really lean it will pick up a ton with jet...if 78's work, try 80's square and so on...
Brian
Brian Hafliger
Re: Pormance on my 408 [Re: Wedgeman] #2107588
07/10/16 11:37 PM
07/10/16 11:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree with Ou812, I never dyno my engines buy I definitely think you should try the 78 jets and then 80.
Re: Pormance on my 408 [Re: Wedgeman] #2107589
07/10/16 11:38 PM
07/10/16 11:38 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I was hoping you jump in Brian...
The plugs are a bit dark and the wideband says rich a bit....
But I should really be faster than just a jet change ?
Dan
Re: Pormance on my 408 [Re: Wedgeman] #2107641
07/11/16 12:43 AM
07/11/16 12:43 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
My Demon will 60 ft 1.29 and go 6.15 at 110 mph, and 1.26 60ft and 6.09 at 111mph. Sometimes 1.42 60ft and still a 6.10 in the 1/8th mile but looks like the picture below. 360/418c.i.--587 production heads--flat tappet cam-Racer Brown STX-22--727 trans--Dana 60 w/ 4.56 gear-- 13x31 goodyear slicks. Your ET should be way better with the 60ft you have, and with indy heads your mph should be a bit better than mine as well as the ET. My intake port flows your exh number of 275
Re: Pormance on my 408 [Re: Wedgeman] #2107665
07/11/16 01:23 AM
07/11/16 01:23 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok your car looks awsome !
So where do you see my problem ?
Dan
Re: Pormance on my 408 [Re: Wedgeman] #2107691
07/11/16 02:04 AM
07/11/16 02:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You start out great then it losses power...
check your fuel supply... are you looking at
the plugs right after you shut down or driving
back to your pit.. sounds like your fat at low
rpm(when you get back to your pit and pulling
the plugs then)... on a 1/8 track its hard to
pull them right after you turn off.. if you have
to drive a bit
wave
Re: Pormance on my 408 [Re: Wedgeman] #2107693
07/11/16 02:06 AM
07/11/16 02:06 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I personally would like more compression and what are your cam specs? With that 60 foot your car SHOULD be flying.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pormance on my 408 [Re: Wedgeman] #2107753
07/11/16 09:19 AM
07/11/16 09:19 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Cam specs are 255*/285* int
263*/293* exh
Re: Pormance on my 408 [Re: Wedgeman] #2107789
07/11/16 11:05 AM
07/11/16 11:05 AM
PA.
"Little"John
"Little"John
PA.
263*/293* exh
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Pormance on my 408 [Re: pittsburghracer] #2107826
07/11/16 12:06 PM
07/11/16 12:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
263*/293* exh
I second that?????????????
Re: Pormance on my 408 [Re: Wedgeman] #2107838
07/11/16 12:33 PM
07/11/16 12:33 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
285/293@.006
255/263@050
I'm sure this is what he's trying to say
Re: Pormance on my 408 [Re: Wedgeman] #2107873
07/11/16 01:48 PM
07/11/16 01:48 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
263*/293* exh
It looks like the first spec is advertised duration and the second is @.50 guys.
Re: Pormance on my 408 [Re: viperblue72] #2107912
07/11/16 02:51 PM
07/11/16 02:51 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Originally Posted By viperblue72
285/293@.006
255/263@050
Sorry, thought it was obvious....
Re: Pormance on my 408 [Re: Wedgeman] #2107915
07/11/16 02:53 PM
07/11/16 02:53 PM
Can you record and look at the wide ban readings for the entire run? If so is it a little rich for the entire run or just the first 100 ft. or so? If so try making it better the entire run thumbs twocentsI had fuel delivery issues that I found with my LM1 and once it was fixed I could jet the carb. up enough to slow the MPH down in the 1/4 mile and 1/8, that was on pump swill and it would leave te starting line at 14.3 and lean out to 15.8 shock It didn't miss or break up at all, the plugs look good also work
You have a lot faster 60 ft than my car ever did, my car ran 9.99 ar 134.+ MPH in the 1/4 mile and low 6.3s at 99 MPH at the local 1/8 mile track work I had to slow it down at both tracks do to the roll bar only and no NHRA certs for me or the chassis whistling
