NHRA PRO STOCK #2107532
07/10/16 10:00 PM
07/10/16 10:00 PM
State of confusion
Thumperdart Offline OP
State of confusion
Was just watching the races I recorded from yesterday and usually freeze frame different parts of the runs or cockpit shots like I just did on Erica`s car and the oil pressure is about 10 lbs. at a 1900 rpm idle. That totally goes against what we usually tell ourselves or others and most cringe at 20-30 at idle.............. shruggy
Re: NHRA PRO STOCK [Re: Thumperdart] #2107533
07/10/16 10:09 PM
07/10/16 10:09 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
might be normal for 0w oil
Without Data, you’re just another guy with an opinion.
Re: NHRA PRO STOCK [Re: sr4440] #2107545
07/10/16 10:21 PM
07/10/16 10:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
And a dry sump oiling system. Something I know nothing about.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NHRA PRO STOCK [Re: sr4440] #2107547
07/10/16 10:22 PM
07/10/16 10:22 PM
State of confusion
State of confusion
Crazy but obviously they've got it figured out..........
Re: NHRA PRO STOCK [Re: Thumperdart] #2107607
07/11/16 12:01 AM
07/11/16 12:01 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Maybe that low so it won't be too high at the 10500 redline. These engines do not sit and idle like a daily driver car.
Re: NHRA PRO STOCK [Re: NANKET] #2107626
07/11/16 12:21 AM
07/11/16 12:21 AM
PA.
"Little"John
"Little"John
PA.
I know I noticed today that Ericas Dodge was idling at 2000 RPM.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NHRA PRO STOCK [Re: Thumperdart] #2107673
07/11/16 01:38 AM
07/11/16 01:38 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I have a hard time even tuning in anymore since I already know greg or jason is going to win.
Re: NHRA PRO STOCK [Re: mopars4ever] #2107695
07/11/16 02:08 AM
07/11/16 02:08 AM
PA.
"Little"John
"Little"John
PA.
A.J's MPH is starting to step up and that's a real good sign.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: NHRA PRO STOCK [Re: Thumperdart] #2107701
07/11/16 02:29 AM
07/11/16 02:29 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nothing unusual for most any non blown heads up deal. Especially with 0W5 or the typical 0W10 oils they use. Mine is at 20-25 at idle. Biggest issue with light oils are valvetrain/spring problems.
Re: NHRA PRO STOCK [Re: pittsburghracer] #2107702
07/11/16 02:40 AM
07/11/16 02:40 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
He had a slightly higher MPH than Anderson today, but Anderson may have hossed the gas on him. It did look like Allen's car spun right at the hit too.
Re: NHRA PRO STOCK [Re: Thumperdart] #2107765
07/11/16 10:08 AM
07/11/16 10:08 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
They will only have 40 pounds at 10,000 too. You can turn a fully assembled ps short Block by hand using the balancer lol....amazing to me.
Re: NHRA PRO STOCK [Re: dthemi] #2107828
07/11/16 12:12 PM
07/11/16 12:12 PM
State of confusion
State of confusion
NICE...............
Re: NHRA PRO STOCK [Re: Thumperdart] #2107840
07/11/16 12:39 PM
07/11/16 12:39 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
I don't know if it's true or not, but I was once told that an old superstock trick was draining the oil and running it, less windage I suppose but bye bye motor. Maybe someone else could confirm or deny that?
Re: NHRA PRO STOCK [Re: twayne24365] #2107843
07/11/16 12:44 PM
07/11/16 12:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Back before synthetics came around Lyn Smith told me you wanted just enough oil in the motor so the pressure just dropped to 0 at the stripe. He would run 3 quarts on heads-up runs.
Re: NHRA PRO STOCK [Re: twayne24365] #2107856
07/11/16 01:06 PM
07/11/16 01:06 PM
State of confusion
State of confusion
3 quarts maybe but no oil wouldn`t fly I would think.......
Re: NHRA PRO STOCK [Re: slantzilla] #2107868
07/11/16 01:41 PM
07/11/16 01:41 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I wonder how many bearings got scorched before figuring out the minimum he could get by with?
72 Plymouth Roadrunner 11.08@123.25
Re: NHRA PRO STOCK [Re: Thumperdart] #2107870
07/11/16 01:43 PM
07/11/16 01:43 PM
kansas
farmboy Offline
farmboy  Offline
kansas
Had an Indy oil pump seize up on a new engine start up. it was idling nicely at 1200 rpm, almost dies when the pump seized, and then sped up to 2000 rpm when it was no longer turning the pump. amazing how much power the oil pump takes to run.
Re: NHRA PRO STOCK [Re: Thumperdart] #2107965
07/11/16 04:08 PM
07/11/16 04:08 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I seen the oil pressure also. I thought it was 0 though. I was waiting for it to go boom on the pass,
Re: NHRA PRO STOCK [Re: Thumperdart] #2107969
07/11/16 04:13 PM
07/11/16 04:13 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
IMO any max effort N/A program from stock to pro stock should only have minimum oil pressure, minimum oil flow, minimum oil cSt, & minimum bearing surface areas to do the job.
Been as low as 35 lbs. @ 8500 rpm in a wet sump super stock.
Re: NHRA PRO STOCK [Re: slantzilla] #2107970
07/11/16 04:15 PM
07/11/16 04:15 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Yep
