Weird battery problem #210711
02/01/09 04:03 PM
02/01/09 04:03 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
My battery will go dead sitting for 3 days but it passed a load test. No system draw. If I drive every day the battery will start the car. Is it possible that even though it passed a load test it could still be bad.
Re: Weird battery problem [Re: stumpy] #210712
02/01/09 04:30 PM
02/01/09 04:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If you unhook the battery cables when fully charged does it still go flat in three days??
Re: Weird battery problem [Re: Dodgem] #210713
02/01/09 04:37 PM
02/01/09 04:37 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
I trying that now. It shows 12.48v. I'll recheck it tomorrow. I just wonder why it passed the load test.
Re: Weird battery problem [Re: stumpy] #210714
02/01/09 04:55 PM
02/01/09 04:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
i don't know but if it's fresh of a charger it should be 12.8 to 13 and fall slightly over night to 12.7 or 12.6 and hold there for weeks??
Re: Weird battery problem [Re: Dodgem] #210715
02/01/09 06:05 PM
02/01/09 06:05 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
something is wrong in that mix,u charged it and it passed the load test...let it sit and the battery is dead..sounds like it's not holding the charge....how old is the battery?
Re: Weird battery problem [Re: AARCONV] #210716
02/01/09 06:07 PM
02/01/09 06:07 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
1.5 years. Ya I'm confused too.
Re: Weird battery problem [Re: stumpy] #210717
02/01/09 06:33 PM
02/01/09 06:33 PM
either the battery is prematurely (terminally) ill or theres a constant draw in the vehicle. Charge it up, take off one cable, let it sit that way for you said 3 days right, If it's OK obviously there is a full time draw somewhere in the car. Might put a VOM on amperes scale on the lowest scale(micro or milli amps) & in series with the cable you took off & see if there's current flowing. I'd try the amps scale 1st then the milliamp scale 2st then microamps so you dont fry your meter if it's flowing alot of current.
Re: Weird battery problem [Re: RapidRobert] #210718
02/01/09 06:35 PM
02/01/09 06:35 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
As I said earlier I did a draw test and there is none.
Re: Weird battery problem [Re: RapidRobert] #210719
02/01/09 06:36 PM
02/01/09 06:36 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep. And don't be surprised to see a draw of about 20-40MA, your clock and stereo memory can draw that much. (make sure the car door is shut too
Re: Weird battery problem [Re: Pacnorthcuda] #210720
02/01/09 06:39 PM
02/01/09 06:39 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
what kind of car and brand of battery are we talking about anyways..
Re: Weird battery problem [Re: AARCONV] #210721
02/01/09 06:46 PM
02/01/09 06:46 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
2005 pt-gt unmarked as to battery brand.. I get a 11ma reading but I don't consider that a draw. It's too little to cause a battery to go dead.
Re: Weird battery problem [Re: stumpy] #210722
02/01/09 07:00 PM
02/01/09 07:00 PM
I would tend to agree but charge it up then unhook it for 3 days then if it's not drained it's time for a new one. It could still be bad to where that small of a draw is enough to disable it even though it load tested OK. & even if you were willing to do without your clock by rigging up a master switch to isolate it every nite it's only a matter of time before it leaves you stranded somewhere
Re: Weird battery problem [Re: stumpy] #210723
02/01/09 10:13 PM
02/01/09 10:13 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Batteries can act in mysterious ways. It should be 12.6 if its fully charged. 12.48 sounds like its showing signs of not taking or holding a full charge.
Re: Weird battery problem [Re: NITROUSN] #210724
02/01/09 10:23 PM
02/01/09 10:23 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
The only draw is radio memory. No seperate clock. Battery is unhooked and time will tell.
Re: Weird battery problem [Re: stumpy] #210725
02/01/09 11:30 PM
02/01/09 11:30 PM
I would still suspect a draw, although it COULD be the battery, just not likely
I'd unhook the battery
The problem is, that modern rigs have SO much "soft" controlled devices, things are not like back "in the day" --you turned something off, it's pretty much off.
It have an alarm? Maybe something is causing "false" activation of the flash warning, something like that
Another approach, let's say you disconnect, and that shows the "right track"
Maybe next, remove a bunch of accessory fuses and see if that eliminates the problem.
Last what kind of "load test" are you referring to? If the "load tester" is handheld, in one hand, then "it ain't" --a load tester that is
Re: Weird battery problem #210726
02/01/09 11:37 PM
02/01/09 11:37 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
No accessories other than the radio to cause a draw. Everything else is off with the key. Like I said I did a through draw test with a VOM and found nothing that would run a battery down in two or three days. The load tester was the cabinet style that senses and charges a battery to full charge before putting a heavy load on it. Then it recharges the battery to full again. I don't trust the hand helds completely but they do work most of the time.
Re: Weird battery problem [Re: stumpy] #210727
02/01/09 11:42 PM
02/01/09 11:42 PM
Well my point is that "everything" is NOT off with the key---I'm not familiar with all the new computerized crap, but here's just one example
On a typical stereo, esp with a heavy outboard amplifier, --even on a "stocker" Some circuits are wired so that the main output transistors are across the buss all the time. This doesn't cause any problems until "a problem arises"
Your alternator is the same way. You have diodes that are "hot" all the time. They CAN and do go bad, and I have seen diodes that "leak."
Without painstakingly analyzing the entire circuit of your vehicle, I don't know--but unhooking the battery will tell you if it's in the vehicle or battery.
Re: Weird battery problem #210728
02/01/09 11:48 PM
02/01/09 11:48 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
That is what a draw test is for. It eliminates all those things you are talking about. Do you know how a draw test works?
Re: Weird battery problem [Re: stumpy] #210729
02/02/09 03:00 PM
02/02/09 03:00 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I had a battery that gave me fits for a couple of years.. Tested out good but things just didn't work right.. Tested each cell and found a bad cell.. Exide battery....
Re: Weird battery problem [Re: stumpy] #210730
02/02/09 03:07 PM
02/02/09 03:07 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You are right there. By my calculations, a 90 amp hour battery would go dead with that draw in 8,181 hours or 340 days.
You can get as much as a 500 ma draw just across a dirty battery.
How much current did the load test put on the battery? It may not be as much as a starter does. The battery may be breaking down under load even if the load test shows it okay. If they are giving you a hassle with the warranty, you might try another branch of the same store.
A third point, in many cars, the battery draw avalanches when the voltage gets low. The 11 ma current can then go up to the amp range as the battery grows weaker. It kind of drops off a cliff and the battery goes dead faster.
Good luck
Craig
