Page 13 of 18 1 2 11 12 13 14 15 17 18
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1992340
01/17/16 12:45 AM
01/17/16 12:45 AM
Parts unknown
590 Challenger Offline
Parts unknown
25.3 book only shows the 25.3 spec. Yes it calls out every mandatory bar, dia. and wall thickness. 25.3 is not that much more work and it's a little heavier and safer. I think 25.5 you have a choice of mild or moly where 25.3 is moly only and has to be tig welded
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 590 Challenger] #1992780
01/17/16 05:41 PM
01/17/16 05:41 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
So the 25.3 just shows the add on bars to what? 25.5 or where does it show the whole frame concept?
I would do moly so tig is no problem. I bend and weld my stuff so I can conform to my size. So should I get the 3,4and 5 to lay a good foundation and build up from there?
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1992802
01/17/16 06:05 PM
01/17/16 06:05 PM
Parts unknown
Parts unknown
25.3 is only a few more bars thasn the 25.5. The 25.3 book shows you everything you need to know. You could start with that. but if you did start with the 25.5 in moly and tig you could later upgrade it to a 25.3. If you used mild you would have to start over to upgrade. Might as well do it all at once thou
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #1992841
01/17/16 06:50 PM
01/17/16 06:50 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The SFI chassi book for the cert you want is about 40 dollars. It list every bar and size. There well worth the money.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: FastmOp] #1992910
01/17/16 08:21 PM
01/17/16 08:21 PM
fredericksburg,va
fredericksburg,va
Found that site awhile back, I'll order both tomorrow and see how they look, thanks
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: cudaman1969] #1999801
01/27/16 03:27 PM
01/27/16 03:27 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
No further picture updates yet. Just buying more parts to get a little further, I have new MSD crank trigger, distributor, wire set to be made, Meziere electric water pump & figuring out the front drive assembly mounting everything to the front plate with a vacuum pump & alternator now.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2106928
07/09/16 06:20 PM
07/09/16 06:20 PM
Parts unknown
Parts unknown
The competition has been at work! (spy photos!!)
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2106964
07/09/16 08:07 PM
07/09/16 08:07 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Beautiful car,I'm a little partial to B5 though.
Mopar to the bone!!!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2106983
07/09/16 09:18 PM
07/09/16 09:18 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Ahh, so that was your Hemi on the Roush Engines facebook page a couple days ago!
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Blusmbl] #2107053
07/09/16 11:44 PM
07/09/16 11:44 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
Yes, everyone was kind enough to give me my own build area to stay after and machine, assemble, fabricate whatever I needed and dyno once I was done.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2120856
07/29/16 07:36 PM
07/29/16 07:36 PM
Parts unknown
Parts unknown
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2120903
07/29/16 09:05 PM
07/29/16 09:05 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I feel sorry for that transmission already.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 72Swinger] #2120920
07/29/16 09:23 PM
07/29/16 09:23 PM
fredericksburg,va
fredericksburg,va
You do know up until the early-mid 70s, Hemi funny cars ran torqueflites
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2121175
07/30/16 10:58 AM
07/30/16 10:58 AM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
The trans will hold up fine for now. With today's power management capabilities I will be taking power out of it to get it to leave anyway and bringing both kits in. Thanks for posting the latest pictures Jeff.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2121918
07/31/16 02:03 PM
07/31/16 02:03 PM
Mo.
racerx Offline
racerx  Offline
Mo.
What's the expected et/mph goal with this setup? work
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2122001
07/31/16 04:24 PM
07/31/16 04:24 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Very nice!
69 GTX 68 Road Runner
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2122523
08/01/16 11:54 AM
08/01/16 11:54 AM
an8sec70cuda Offline
Love that car.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2122593
08/01/16 01:44 PM
08/01/16 01:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Ratio will be the issue. 2.45 low on radials, lots of nitrous, big block = nearly impossible to manage early. You should look into a 2nd gear leave valve body
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: Monte_Smith] #2122793
08/01/16 06:22 PM
08/01/16 06:22 PM
Motor City
6PKRTSE Offline OP
6PKRTSE  Offline OP
Motor City
It's not makimg that much power. That will be an upgrade eventually. Right now I just have to run with what I have.
Re: Coming to a strip near you, 25.5 (70) Challenger [Re: 6PKRTSE] #2226679
01/03/17 10:49 PM
01/03/17 10:49 PM
Parts unknown
Parts unknown
