Will tapered spacer improve my 440 w/alum heads and intake?
#2106504
07/08/16 09:13 PM
07/08/16 09:13 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Ive bought an AED 1/2" open wooden spacer for my 440 to keep the heat out of my carb. 440, lightly ported aluminum sidewinder heads, eddy rpm intake, eddy 800 thunder avs carb, 1 7/8" exh, 10.5:1 compression, 254@50 duration 554 lift single pattern, 4000 stall, 4.10 dana. 4000lb car.
Im doing a little research on spacers and Im not knowledgeable enough to predict if a 1" tapered spacer (or other size) from wilson will improve my combo or just do the same job as my 1/2" for 4x the price. I would just buy one and try it if it wasnt so expensive.
Re: Will tapered spacer improve my 440 w/alum heads and intake?
[Re: Adam71Charger]
#2106509
07/08/16 09:23 PM
07/08/16 09:23 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There's really only one way to know what it will do on your exact combo.
[Re: Adam71Charger]
#2106554
07/08/16 10:57 PM
07/08/16 10:57 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Most running the taper/contoured spacers have said it leans out the mixture to require a carb change/adjustment...........
[Re: Adam71Charger]
#2106661
07/09/16 02:03 AM
07/09/16 02:03 AM
fast68plymouth
So. Burlington, Vt.
I'm not sure that a 4 hole merge spacer is going to be the hot ticket sitting on top of a dual plane manifold.......... But it's easy to try.
