Upping the Comp ratio on a 400, engine builders please #2106422
07/08/16 07:39 PM
07/08/16 07:39 PM
west palm beach, florida
modelmakerinc Offline OP
OK SUPER LOW BUCK DEAL. basically stock '76 400, runs well, doesn't smoke but low on power. I want to do nothing more than swap out the low compression pistons for some KB240 ones, I do not want to do this if it needs to be bored oversize, I do not want to do any thing other than bump the compression.
QUESTION....when the heads come off, with a dial/bore gauge what is the maximum the cylinders can be to use standard bore pistons /rings???
If it has too much wear and needs to be bored, I will not take it apart father and it will go right back together.
If I can go the route of new pistons, I will mill the heads and deck the block only minimal to clean-up the surfaces, and be able to use fel-pro composite gaskets and gain cc's
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106449
07/08/16 08:03 PM
07/08/16 08:03 PM
Idaho
LaRoy Engines Offline
Idaho
Oversize pistons and rings cost no more than the standard size. If you are into the block far enough to deck it, it is only about $180 to bore and hone with a deck plate. Maximum? Best call the manufacture directly.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106457
07/08/16 08:10 PM
07/08/16 08:10 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Why not bore and hone it if you're going to deck it?
Stock head gaskets I believe are steel and only .020" thick, Felpro's are .039 thick.
If the bore looks smooth and shiny it needs to be honed minimum.
The KB240's require the bore to be pretty tight .002-.0025" so I don't believe a well worn engine will be that tight.
Sound like this is waste of effort to even take it apart.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106494
07/08/16 08:58 PM
07/08/16 08:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
my experience with the kb's i've used is that the bore size needs be on the money to achieve recommended clearance. .001"-.002" larger and they're pretty noisey, in fact they're a little noisey cold at .002"-.0025".
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106522
07/08/16 09:40 PM
07/08/16 09:40 PM
I would like to do alot more and have thousands to put into it...However consider it an old school, shade tree, no money to do it "right" build.
The pistons and rings are being donated to the cause so I don't have to buy $600 new ones, money will still be spent on bearings and gaskets. But little else.
I understand from the replies I am looking for a max bore to be 4.342.
We're there not oversize rings once available?
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106532
07/08/16 10:01 PM
07/08/16 10:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
something like a .005" over ring won't do anything if the bores too big for the piston. the top ring gap will need to be opened up to around .030" anyway. taper will be the issue. setting the gap at the top of the cylinder may be too tight at the bottom. seems like it would be easier to just mill the heads .060" and ring and bearing the old stuff.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106606
07/09/16 12:35 AM
07/09/16 12:35 AM
If the bore tapered is over .003 from top to bottom I would bore it and replace the pistons and rings twocents That being said some old time mechanics back when I was young, right after dirt was invented whistling ,use to say if has over .015 taper bore it downshruggy
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106657
07/09/16 01:51 AM
07/09/16 01:51 AM
Thanks guys, I will consider this idea further. I may post results, if things work out. LOL.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106729
07/09/16 10:26 AM
07/09/16 10:26 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What is your budget? IMO, it is really hard to tear into a short block, change a bunch of stuff, and come out on the cheep.
Also, in my limited experience, it seems that a really good set of heads on even a well seasoned short block, can give a big bump in performance.
If you sell what you have, and buy some aluminum heads, have them gone through, mill to 70 or 72 cc, you might not be into it for much more $ than what you are thinking now, with a more certain outcome. Just a thought.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2106791
07/09/16 01:03 PM
07/09/16 01:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
This is my experience as well.
Cheapest option in my mind is, mill the heads about .060-.070, steel shim gaskets, adjustable pushrods(if you don't have an adjustable valvetrain now).
While the heads are off and apart, have them cleaned and do a quicky bowl blend.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2108041
07/11/16 06:27 PM
07/11/16 06:27 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
On a really tight budget like that, I'd just put a high stall converter in the car and run with the low compression engine.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2108057
07/11/16 06:44 PM
07/11/16 06:44 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
The motor is 40 years old. I feel that is why it's down on power. Going thru all the work and expense you are talking about to only increase the compression, and nothing else, I feel will give you less than exciting results. The motor is tired dude. I recently tore down 4 1976 400's. It will need everything.
2011 Drag Pak Challenger
Re: Upping the Comp ratio on a 400, engine builders please [Re: lewtot184] #2108095
07/11/16 07:42 PM
07/11/16 07:42 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Better to hear 'em than to smell 'em. grin
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2108674
07/12/16 01:21 PM
07/12/16 01:21 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You'll probably fine a pretty good ridge at the top of those cylinders. At least make sure the new rings dont crash into that.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2108735
07/12/16 02:37 PM
07/12/16 02:37 PM
Boise
Moparteacher Offline
Boise
Run a ridge reamer on the top of the cylinders prior to piston removal. Ball hone with an appropriate grit to match the rings, and put it together. If you're worried about piston slap you may consider knurling the pistons and then use a flat file to size the pistons to the individual cylinder. You'll have to check with a machinist as to whether a hypereutectic will take a knurl the same as a cast piston.
Stock bore is 4.342. Rings are available in 4.350 for $40. That's .008" over. File fit the rings. Run the steel shim gasket sold through Summit for $25.
https://www.summitracing.com/parts/dcc-4286754/overview/
It'll use a little oil and make a little noise, maybe, but it'll run, just don't expect to get 200k miles out of it.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109332
07/13/16 01:06 PM
07/13/16 01:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where is Dan when you need him ??
You are going to do ALL that and you can't come up with MAYBE another $300 to BORE it ... seriously ???
Ignore the ridge reamer recommendation , if you don't know what you are doing with it then you will do more HARM than good to the block.
I have personally been burned by someone that didn't know how to use one ... had to sleeve a block because it took .075 overbore to get a clean pass, top to bottom, on one cylinder , .040 on the one next to it , the 2 next to those at .030 , the other side would have cleaned at less ...
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109350
07/13/16 01:51 PM
07/13/16 01:51 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I just had to take a block to 4.402" because some talking chimp used a ridge reamer. Block surface cleaned up at 9.965 deck height, and that was with .020 slope from one end to the other.
Either do the shortblock right, or just do head work and stick it on the stock shortblock. S/F....Ken M
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109367
07/13/16 02:20 PM
07/13/16 02:20 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
After having gone down this road, I wouldn't even crack open the cylinder heads. If you're not going to do it right to get a good seal, don't bother. Your money would be better off spent on alternative upgrades. I would do a centrifugal supercharger, or maybe a transmission/rear gear upgrade instead.
Re: Upping the Comp ratio on a 400, engine builders please [Re: modelmakerinc] #2109371
07/13/16 02:24 PM
07/13/16 02:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have had a blast doing stuff on the cheep. I'd just stick a cam in it 😄
Re: Upping the Comp ratio on a 400, engine builders please [Re: JohnRR] #2109430
07/13/16 04:03 PM
07/13/16 04:03 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I agree. Usually if the ridge is that bad, the block needs an overbore, and most people usually take too much out with a ridge reamer making things worse.
Been there and done that and learned from my mistake.
A friend raced a low compression 400 engine with decent results. It had a decent sized cam and ported heads, with 6-pack intake and headers. He just used a high stall converter and higher gears to get past the weak low end torque.
