Would changing pvc from rear of carb to the front change AFR #2106469
07/08/16 08:21 PM
07/08/16 08:21 PM
central il.
second 70 Offline OP
central il.
Would changing the pvc hose from the back power brake port on my edelbrock to the front pvc port on front of carb change my carb settings? AFR? This is on a 426 stage V manifold 2 four setup 1 to 1 linkage and changing the hose from back of rear carb to front of front carb.
Re: Would changing pvc from rear of carb to the front change AFR [Re: second 70] #2106550
07/08/16 10:51 PM
07/08/16 10:51 PM
Boise
Moparteacher Offline
Boise
Probably not, but it will improve fuel distribution and idle quality.
Re: Would changing pvc from rear of carb to the front change AFR [Re: second 70] #2106556
07/08/16 10:59 PM
07/08/16 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The orifice size didnt change so no it wont hurt
but as said it MIGHT help distribution some... you
might need to readjust the carbs being that the leak
will be at the front and it might be a tad lean(might)
wave
