Page 3 of 4 1 2 3 4
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2105908
07/07/16 09:32 PM
07/07/16 09:32 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Originally Posted By Moparnut426
mallory at my local shop is ridiculous, like 100 bucks a slug
If that's with labor, that's the going rate here in Chicago. It's kinda a PITA to put heavy metal in right. S/F....Ken M
Re: 383 piston with 440 crank and rods [Re: EchoSixMike] #2105916
07/07/16 09:55 PM
07/07/16 09:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the price I paid installed... had 3 chunks
put in.. always from the sides
wave
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106024
07/08/16 01:06 AM
07/08/16 01:06 AM
Boise
Moparteacher Offline
Boise
I put a 440 crank in a 383 25 years ago. I had the counters turned down to clear the pistons and the block. I used beam polished 383 rods and modified TRW pistons. This was before cheap stroker kits were on the market.
I cut .175" off the top of the piston and trimmed the bottom of the pin bosses. It shaved about 200 grams off each piston.
The TRW l2315f-30 slug still had well over .2" of material in the center and thickened up considerably as you moved out towards the ring lands. In fact, the centering hole in the middle of the head on the forging used to mount the piston on the lathe was still visible.
The crank took at least six slugs of mallory and over $1k to finish and balance.
Just sayin' save a little on the pistons and rods now may cost you more in the long run when it's time to balance.
Re: 383 piston with 440 crank and rods [Re: DARTH V8Я] #2106167
07/08/16 11:39 AM
07/08/16 11:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By DARTH V8Я
crap ... positive .179 LMFAO. Sorry
haha ...
Re: 383 piston with 440 crank and rods [Re: DARTH V8Я] #2106202
07/08/16 12:48 PM
07/08/16 12:48 PM
Finally a HUSKER again
Moparnut426 Offline OP
[censored]... positive .179 LMFAO. Sorry
That shows a 1.5 compression height, THe pistons diamond makes, and the one I listed is wrong.
I posted the wrong number before....
Fits: Big Block, 383 w/440 Rod
Bore (in): 4.280
Stroke (in): 3.750
Rod Length (in): 6.768
Piston Material: Forged aluminum
Piston Style: Flat Top
Compression Distance (in): 1.320
Dish Volume (cc): -4.0
Pin: .990 x 2.930
Piston Ring Grooves: 1/16" x 1/16" x 3/16"
Quantity: Sold as a set of 8
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106209
07/08/16 01:05 PM
07/08/16 01:05 PM
that puts me at .025 in the hole
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106225
07/08/16 01:24 PM
07/08/16 01:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I have to do the math , it shouldn't be that deep , have you had the block squared yet ? If not do it FIRST , order piston in the bore size you need and tweak the CH
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106255
07/08/16 02:29 PM
07/08/16 02:29 PM
The block is at the shop waiting on pistons. He is squaring the block, and also checking counter weight clearance. Some take shaving and some don't I guess so he is checking that as well.
Re: 383 piston with 440 crank and rods [Re: GTS340] #2106360
07/08/16 06:12 PM
07/08/16 06:12 PM
dogdays Offline
dogdays  Offline
I repeat: Complaining about 20 grams in an engine that came stock with piston/pin assemblies that were over 1000 grams is hilarious.
Yes I know the generally accepted balancing formula for V8s. Take 40 grams off the piston/pin and the 20 grams goes away, IF the extra weight is concentrated at the big end. If it's the result of a slightly heavier than stock rod beam then it'll be less than 20 grams. Lightening the rod journal would be my fix, like Chrysler did on the 340.
Suggesting someone will need Mallory because of an extra 20 grams in connecting rod weight is pure and simple "putting up a straw man to knock it down". That doesn't fly at the debate club and not here, either.
R.
As for the Chinese lying about metal composition, if they are indeed trying to do that, it's why we aren't buying directly from them. The middlemen, i.e. the Eagles, Scats, 440Sources, RPMs, Hughes, etc are doing the due diligence. They have to keep tabs on the product or else go out of business. That shouldn't be too hard to understand.
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106379
07/08/16 06:40 PM
07/08/16 06:40 PM
My block is decked, and he went to a 9.865, and with the piston we decided on that puts me .0010 in the hole.
So Im pretty good with that.
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106401
07/08/16 07:13 PM
07/08/16 07:13 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
9.865 most likely a typo
9.965?
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106413
07/08/16 07:27 PM
07/08/16 07:27 PM
nope. He took .015 off one side and .018 off the other side.
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106419
07/08/16 07:34 PM
07/08/16 07:34 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
For your sake I hope its not 9.865
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106432
07/08/16 07:47 PM
07/08/16 07:47 PM
why? it comes out to .010 in the hole.
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106434
07/08/16 07:49 PM
07/08/16 07:49 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Because 9.865 is .115 short of blueprint deck height (9.98)
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106440
07/08/16 07:56 PM
07/08/16 07:56 PM
IDK I just know what he told me, and the block had factory stamps on it, so I don't think its been super decked. Ill call him Monday to double check.
Re: 383 piston with 440 crank and rods [Re: dogdays] #2106454
07/08/16 08:08 PM
07/08/16 08:08 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
R.
Aren't you an engineering professor? A data driven field where ASSumptions can yield catastrophic results?
How do you know what bobweight his current crank was balanced at?
Yes the rod is 20 grams heavier total, it also has a .104 smaller wrist pin bore, who is to say the rod is not 85 grams heavier than a stock rod on the big end?
My point is no one in this thread has the data to determine if the crank will balance out fine or need mallory and no need to call in the debate team
Re: 383 piston with 440 crank and rods [Re: Moparteacher] #2106576
07/08/16 11:41 PM
07/08/16 11:41 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
For reference. I'm putting a 452 together right now using a factory 3.75 440 crank. Because I have parts laying about. I took .120 off the counterweights with a lathe, and still had to heavily bevel the edges and grind the block for clearance.
Using a 1.12 CH Icon piston(IC827-granted, super light) and a Manley 6.965 hemi rod(heavy thing like 960 gms IIRC), the bobweight is just over 2320grams, I have to take over 180 gms off the crank on both ends still.
A 1.200 inch piece(what commonly fits in BB cranks) of 1 inch diameter Mallory adds something like 120gms gain to a crank. I'm at home of else I'd actually look. 6 pieces is roughly +300gms on either end. I find that incredibly hard to believe on a wedge build...any wedge build.
I think you got sodomized by the guy balancing that crank, or maybe they went crazy when turning the CW's. S/F....Ken M
Re: 383 piston with 440 crank and rods [Re: Moparnut426] #2106692
07/09/16 04:30 AM
07/09/16 04:30 AM
Boise
Boise
Probably both. I counted the sticks. Never again. I was just a wee pup back then and didn't know no better. I be a whittle smarter now.
Re: 383 piston with 440 crank and rods [Re: EchoSixMike] #2106727
07/09/16 10:24 AM
07/09/16 10:24 AM
We figured were gonna have to take .150 to clear. I sure hope cause Im having a hard time finding a machinist who wants to do it. They all seem scared to make the cut. I told them all its no big deal, I wish I had a lathe good enough cause I would do it myself but the one I have access to is way to outa spec and would sing like a canary if I chucked it up.
Page 3 of 4 1 2 3 4
