e-85 Tuning #2104538
07/05/16 10:38 PM
07/05/16 10:38 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Went racing over the weekend and car was much slower than normal and seemed rich. I went 3-jet sizes leaner in the rear, and two jet sizes leaner in the primary with no change in ET or MPH?
Checked my fuel and it was about 72% Ethanol.
Today I bought some E-98 to add to the fuel. Will this work to help get back around E-85?
I still have not wired the MTX-L wideband O2 sensor, but do I need to re-program the gauge for E-85?
Re: e-85 Tuning [Re: 451Mopar] #2104624
07/06/16 01:17 AM
07/06/16 01:17 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
you should be able to mix the 98% and 72% to get 85%.
Don't know your comp ratio, but I would stay away from 72-80%.
Can the mtx-l be set to lambda? The fuel type or percentage isn't required with lambda. .75-.80 lambda will be safe and make good power.
Don
Re: e-85 Tuning [Re: 451Mopar] #2104708
07/06/16 07:49 AM
07/06/16 07:49 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
^^^It work for me thumbs^^^did you purchase that fuel in a 55 gallon drum? Wondering if it can be purchase in something smaller say 25 gallons work.
Re: e-85 Tuning [Re: 451Mopar] #2104997
07/06/16 04:06 PM
07/06/16 04:06 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
They had 55-gallon and 5-gallon. I just got the 5-gallons.
Re: e-85 Tuning [Re: 451Mopar] #2105064
07/06/16 05:45 PM
07/06/16 05:45 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
well I run e-85. Jet changes don't do much change air bleeds then you will see a change
Re: e-85 Tuning [Re: 451Mopar] #2105101
07/06/16 06:48 PM
07/06/16 06:48 PM
I have done some tuning on my motor on E85, mostly at a dyno in Klamath Falls OR at 4300 ft. I have since reinstalled the original jets (that fuel teted to be E75 winter mix shock)but I haven't jetted it up at the track yet on back to back test to see if it wants richer or not confused I do test the E85 now and find that when the fuel sits in the plastic fuel jugs or metal cans over a period of time the Ethanol content increases, not decreases due to the gasoline evaporating out of the fuel shruggy I had 15 gallons sitting in three different containers in the race car trailer since last October, one can and two jugs. They tested in May to be between 87 and 90 % shruggy I need to buy some pure Ethanol or at least E98 so I can play with mixing it with the fuel I have to get all of it to a set level of Ethanol instead of having 10 to 15 % differences in batches work
Re: e-85 Tuning [Re: 451Mopar] #2105209
07/06/16 08:41 PM
07/06/16 08:41 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Anyone here mix a 5 gallon jug of e-98 with fuel? Wondering how much gas is required to reach e-85?
Re: e-85 Tuning [Re: 451Mopar] #2105221
07/06/16 08:57 PM
07/06/16 08:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you plan to use much E-85, especially blending your own.....a Hydrometer will be required
Re: e-85 Tuning [Re: Monte_Smith] #2105427
07/07/16 02:11 AM
07/07/16 02:11 AM
Monte, what range hydrometer range do you recommmend for E85? I've been testing my pump E85 the the Quick Fuel water tester, I do have gas hydrometer left over from racing NHRA stock back when they checked the specific gravity of all the gas we could run back then. Once they switched to the dialelctric tests all that went away shruggy
Re: e-85 Tuning [Re: 451Mopar] #2105660
07/07/16 02:05 PM
07/07/16 02:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
GOOD E-85 will be in the .793 area at 60*. The problem with regular E-85 is that it is pump swill and as a result is VERY inconsistent. It can be anywhere from E-55 to E-90 and everywhere in between. Unless you buy it by the drum or mix your own, you will never be guaranteed of its consistency. It's junk fuel, just like any other pump gas
Re: e-85 Tuning [Re: Monte_Smith] #2105663
07/07/16 02:14 PM
07/07/16 02:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I get my VP-101 unleaded from a local Arco station is that junk too........... work
Re: e-85 Tuning [Re: 451Mopar] #2105797
07/07/16 06:16 PM
07/07/16 06:16 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I have the quick fuel tester Cab_Burge mentioned, but no Hydrometer.
I plan to switch where I buy the fuel, and maybe just buy 55-gallon drums of Real E-85 race fuel?
Re: e-85 Tuning [Re: 451Mopar] #2105815
07/07/16 06:48 PM
07/07/16 06:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I was running E-85 I tested(same tester as
you have)and the one place I bought from it had
to be summer fuel and it tested at 85-86 and when
it tested good I bought 2 55 gal drums at a time
wave
Re: e-85 Tuning [Re: 451Mopar] #2105842
07/07/16 07:35 PM
07/07/16 07:35 PM
NE Indiana
momopar Offline
momopar  Offline
NE Indiana
There is a chart to use your wideband as is set for gas. I just don't know if it is allowed to include the link?
I haven't posted in 7 years so I don't want to get in trouble.
Re: e-85 Tuning [Re: 451Mopar] #2105873
07/07/16 08:36 PM
07/07/16 08:36 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Some other issues with ye ole pump E85 is what they use to denature it. Sometimes they use something called "natural gasoline", and it's the dregs of the gasoline world. When fuel costs are high, you can bet it's the fuel of choice.
You can water test E85 with a graduated beaker, and determine what percentage the ethanol is. Doesn't tell you what's in the "gasoline" side, just how much.
I've gone to VP C85. Works great with nitrous, and makes more NA power than any pump mix I've found. Trouble is, it's a little expensive, like 5+ bucks a gallon, and it's chock full O MTBE, and some other unsavory additives. Up side is, whatever anti corrosion spooge they use really works. Can sit, and sit without turning to white goo.
Re: e-85 Tuning [Re: dthemi] #2105895
07/07/16 09:08 PM
07/07/16 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At the one place I bought from I always went inside
to see the drop sheets for the E-85... all of ours
in the Detroit area was a 2 part drop... ethanol and
the regular gas... it told what it was and the percentage
(number of gals each).. at first(the first couple times
they looked at like I was crazy) until I explained what
I wanted to see.. usually the manager understood... then
I could see the total content of each component.. after a
few times they knew what I was asking for... plus they sorta
got use to me
wave
Re: e-85 Tuning [Re: 451Mopar] #2105902
07/07/16 09:26 PM
07/07/16 09:26 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Hey P body, grab a fiver of C85, and see what you pick up sometime.
Re: e-85 Tuning [Re: dthemi] #2105906
07/07/16 09:29 PM
07/07/16 09:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry I cant anymore.. sold my engine... now I
use cheapo pump crap in the Rampage
wave
Re: e-85 Tuning [Re: Thumperdart] #2106019
07/08/16 01:00 AM
07/08/16 01:00 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's not pump gas.
And as far as knowing the percentage drop like MrP said, that still doesn't tell you WHAT they dropped, just how much of it
Re: e-85 Tuning [Re: Monte_Smith] #2106070
07/08/16 03:00 AM
07/08/16 03:00 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It`s out of a pump at Arco and comes in drums just like the corn stuff............ shruggy
