70 E body passenger side mirror #2105181
07/06/16 08:18 PM
07/06/16 08:18 PM
central P.A.
HEMIDOG 70 Offline OP
central P.A.
I have a passenger side mirror on my 70 Challenger that was rechromed. The glass vibrated out of the mirror housing. Amazingly it did not break when it hit the road. The glass along with the chrome around it,the swivel with the splined stud all came out of the mirror housing. Were these just pressed in originally? Any thoughts on expoxy's or just some permatex on the splines to keep this thing together. The swivel mechanism is fine the mirror stays put when adjusted. The only problem is the splined stud to the outer housing came apart.
electrciali problem [Re: HEMIDOG 70] #2105198
07/06/16 08:31 PM
07/06/16 08:31 PM
btomasko Offline
btomasko  Offline
electrical problem 2002 town & country
The battery is contiual dead, it has been replaced twice and the alternator also has been replaced twice yet the battery still is dead, what would be the cause of it being dead all the time,everything else seems fine thanks.
Re: 70 E body passenger side mirror [Re: HEMIDOG 70] #2105335
07/06/16 11:49 PM
07/06/16 11:49 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Pretty sure they were just pressed in originally. I would think either epoxy or some JB Weld should do the trick.
