electric fan recommendations #2104055
07/05/16 02:14 AM
07/05/16 02:14 AM
Nevada Iowa
dodgepaul Offline OP
Nevada Iowa
I'm looking for input on electric fans for our b-body's. I have a big horsepower Indy 572 Hemi in a '68 Charger. I'd like a double fan with shroud but after cruising all the likely websites haven't found any I liked. I need a shallow depth of less than 3 inches, or have considered a pusher fan, lotsa room up front. Car will see street and strip activity. My radiator is a 26 inch wide, top and bottom tank aluminum. Similar in fit to a stock piece. quality fans with quality shroud. Ideas??? Thanks
1970 4spd Superbird, '69 Charger 500 Daytona clone,2015 Hellcat 6-spd B-5 Blue,1968 572 Hemi Charger,70 GTX 535 6-pac 4 spd,69 GTX 440 4-speed Super Trac Pac Car, 1973 383 Barracuda, and a couple Cummins
Re: electric fan recommendations [Re: dodgepaul] #2104121
07/05/16 10:11 AM
07/05/16 10:11 AM
moparx Offline
moparx  Offline
for what it's worth, i'm not a fan [i know, poor joke] of pusher fans because they have a tendency to block airflow in a normal, going down the interstate cruise situation. they may be a band-aid for when stuck in traffic, but that's about it. since your car is not stock, and you have minimal clearance in front of the engine but lots in front of the core support, if you can't find something to fit where you want, i would consider modifying the core support to move your radiator to the other side of the support to gain the couple of inches needed for a puller fan assembly. maybe not the answer you wanted, but certainly not a hard or difficult job to accomplish, even though you are already painted up nice. also, make sure your electrical system is upgraded to support the needed amperage draw a good fan system requires. just my opinion of course. your results may vary......
beer
very nice charger by the way ! up mine will never be that nice.....
Re: electric fan recommendations [Re: moparx] #2104160
07/05/16 11:48 AM
07/05/16 11:48 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Technically, doesn't a pusher and a puller fan block a radiator the exact same amount, but the difference is in the turbulence caused by the electric fan the real issue on which side its located? work
Re: electric fan recommendations [Re: dodgepaul] #2104171
07/05/16 12:17 PM
07/05/16 12:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Your depth is going to limit you. The higher CFM fans typically have thicker motors. A pair of staggerd 12 inch fans mounted to a custom shroud may get you there. We just shoehorned a pair into a 70 GTX with a 440 and a serpentine setup. I like Spal and Flexalite fans. beer
Re: electric fan recommendations [Re: dodgepaul] #2104230
07/05/16 02:06 PM
07/05/16 02:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If going electric you MUST get fans that pull heavy amperage.
Forget CFM. That is an unregulated number. They can hang a fan from the rafters in a gymnasium and say it flows 50,000 cfm. Then, you get it home and it barely moves 300 cfm with a radiator in front of it.
The only way to see how much work it will do is to look at the amperage. Do not consider anything under 30 amps. Expect to see 60+ amps on startup.
Those monster Mercedes fans we played with may not fit in the room you have. Even with the soft start feature they would draw over 60 amps on start and pulled 50 amps while running.
Look for OE paired fans that are split. You may be able to squeeze them into your engine compartment.
If it's on the shelf at Pep Boys, Autozone, O'reilly, etc then don't bother. Walk right on by.
Again, avoid pushers if at all possible. I ran multiple tests and found that they always blocked air on the highway.
- Stu Harmon
Re: electric fan recommendations [Re: TJP] #2104318
07/05/16 04:55 PM
07/05/16 04:55 PM
Nevada Iowa
Nevada Iowa
Did you use a premade shroud? or make your own? I planned on using twin puller fans if I can find a shroud that works. So that will give me allot of clearance being offset from the pulley at center.
Re: electric fan recommendations [Re: moparx] #2104321
07/05/16 04:57 PM
07/05/16 04:57 PM
Nevada Iowa
Nevada Iowa
beer
Im not a fan, lol, either of pushers. But haven't had much luck find a shroud that worked for me with the limited space available. Which one wouldn't think would be hard to find in the first place. I'm not the first guy to do this by any means, lol. And thanks, she did turn out pretty nice!! If I do say so myself
Re: electric fan recommendations [Re: dodgepaul] #2104332
07/05/16 05:15 PM
07/05/16 05:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"If going electric you MUST get fans that pull heavy amperage. "
Wish this had been from another source here, because its always a rock throwing contest, BUT I believe it is so misleading by omission, that it should be disputed. I can give a bunch of analogy's, but the number one measurement of a fan's effectiveness is how much mass of air it moves evenly, thru your installed radiator, amperage alone is a poor, and not a direct factor, in measuring that task.
Re: electric fan recommendations [Re: dodgepaul] #2104384
07/05/16 06:31 PM
07/05/16 06:31 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
It's all about your combination. New cars have electric fans but their job is to cool at low speeds or stop & go traffic. All aftermarket manufacturers claim a CFM but that's an unrestricted flow rating. Look at it this way. If an electric fan pulls X CFM, that flow would also be equal to the flow at X MPH. Once you exceed that X MPH, the constant speed fan is useless. Now the flow needed has to be greater than the restriction of the fan body and the shroud.
I started with thin flat shroud that had about 1-2 inches between the shroud and the radiator core which was too close. The shroud had some openings with small rubber flaps to allow excess air to pass but were to small to make a difference. I had two 10" fans (22x18" radiator) that were the highest advertised CFM I could find. Obviously, at speed the combination became a big restriction. All the air had to funnel its way through the two 10" holes with fans in them and with only 1-2 inches clearance between the shroud and core. I finally got it right, lesson learned. Would that setup work on a different car, absolutly.
Sorry about the long winded post. Congratulations to the guys that got it right the first time and good luck to you.
Re: electric fan recommendations [Re: dodgepaul] #2104404
07/05/16 06:59 PM
07/05/16 06:59 PM
Nevada Iowa
Nevada Iowa
A few more pics of the car from Mopars in the Park last month.
Re: electric fan recommendations [Re: shorthorse] #2104413
07/05/16 07:14 PM
07/05/16 07:14 PM
Nevada Iowa
Nevada Iowa
so what did you wind up using? I can see the argument from both points for amp and cfm, so yes I agree it's a "right combination" issue.
Re: electric fan recommendations [Re: dodgepaul] #2104430
07/05/16 07:38 PM
07/05/16 07:38 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I used the mercedes fan in my 67 Coronet and it works great with the champion 3 core rad. But it is a very tight fit. A member here sells the controller so there is a nice soft start plus it only runs hard when it needs to. I'm also using a gm 140 amp alt. which handles the additional amperage. I have A/C and a high horsepower 493 and my car stays nice and cool.
Do a search here on moparts and you should be able to find all the info you need to install it.
Oct. 2012 Coronet fan 001.jpgOct. 2012 Coronet fan 003.jpgDSCF3589.JPGDSCF3639.JPG
Re: electric fan recommendations [Re: dodgepaul] #2104591
07/06/16 12:27 AM
07/06/16 12:27 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Ford contour dual fan set up.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: electric fan recommendations [Re: dodgepaul] #2104603
07/06/16 12:42 AM
07/06/16 12:42 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We made the shroud as there was nothing available.
As far as the Amperage vs CFM comment, There is some validity to the comment, However, a high amp fan motor with a poorly designed blade will draw the amperage but not move the air.
An efficiently designed fan and motor will move the air while drawing minimal amperage. The trick is to find a supplier that does not "FLUFF" their numbers. Again, I like Spal and Flexalite.
Welcome to the world of Cooling whistling
Re: electric fan recommendations [Re: TJP] #2104617
07/06/16 01:08 AM
07/06/16 01:08 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
What about an oem fan setup from a later model vehicle? My brother ended up getting a used electric fan off a supercharged Pontiac Bonneville (iirc) in the wrecking yard for his Oldsmobile steet/strip car. The setup has two small individual fans side by side with built-in shrouds over each one and is pretty slim. The engine is on the verge of being not streetable (11.7 compression, and a hefty solid roller cam) and this junkyard fan setup handles it with ease.
Re: electric fan recommendations [Re: dodgepaul] #2104715
07/06/16 08:27 AM
07/06/16 08:27 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The Mercedes fan like Feets recommended, Lincoln Mark 8, 4.6L Thunderbird, HHR, all good candidates for fans.
Re: electric fan recommendations [Re: shorthorse] #2104740
07/06/16 09:32 AM
07/06/16 09:32 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
" Look at it this way. If an electric fan pulls X CFM, that flow would also be equal to the flow at X MPH. Once you exceed that X MPH, the constant speed fan is useless. Now the flow needed has to be greater than the restriction of the fan body and the shroud. "
If you are assuming the the electric fan does not have forward facing into the airstream intake, because if it does, the cfm will be higher then the cfm at standstill.
Re: electric fan recommendations [Re: jcc] #2104852
07/06/16 12:28 PM
07/06/16 12:28 PM
moparx Offline
moparx  Offline
yes, i think i didn't explain correctly. both fans [if identical] will move the same amount of air. however, most cooling systems, if in good working condition, do not need a fan at "x" speed because the airflow through the core is enough to cool the radiator. this applies to mechanical and electric fans both. where the pusher fan creates a problem, is the fan and brackets block this air flow through the core by the amount of area the fan system takes up. a puller, by contrast does not because the full square inch area occupied by the fan system is behind the core, and the airflow through the grille opening to the core is as much as it can be [or is designed for]. where the majority of turbulence comes into play is when a pusher fan is used with a puller [of either type]. i "think" each type kind of work against each other even though the fan blades are designed to make the air flow toward the engine. not saying a pusher system won't work, but i really haven't seen an aftermarket setup that impresses me. and if using a mechanical fan and a pusher "just in case", i would rethink the whole system, including fan, water pump, radiator, and definitely use a shroud. without seeing the OP,s setup in person, i really can't offer a solution, but i think a pusher fan setup is not going to be it. remember, just my opinion.
beer
Re: electric fan recommendations [Re: dodgepaul] #2105049
07/06/16 05:19 PM
07/06/16 05:19 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What radiator, and how much clearance from radiator to water pump pulley?
Are you running A/C too?
I just changed my Coronet from a Champion 4-core with Ford contour fans to a slightly thinner Griffin dual 1.25" core radiator with dual 13" Spal puller fans that are the "thin" 2" design for clearance these are rated at 1,250 cfm and 10-amps each. They are actually from Be Cool #75039, which had a rebate when I bought them and they come with mounting hardware which is an extra cost if ordering from Spal. If you have the clearance, the standard thickness (3.4") fan will pull more air (1,710 cfm.)
The fans are mounted diagonal across the radiator and cover most the radiator.
I made this change over the winter, and I don't have the suspension finished on the car to tell how these changes work.
I also have A/C and I may mount a 17" pusher in front of the A/C condenser wired to only come on with the A/C?
Re: electric fan recommendations [Re: 451Mopar] #2105200
07/06/16 08:34 PM
07/06/16 08:34 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Not much help here sense you already have a radiator, and if you stay with the twin fan idea.
I'll just show my combo for the single fan idea.
70 RR 475" Hemi, ported Stage V, small roller cam.
26" Glen Ray with Max Cooling core.
Mercedes "Monster" fan.
Roughly 2800 miles on the combo.
I wanted a close to stock look with better than stock cooling. hooziewhatsit's controller decides what fan speed is needed.
I shaved & also cut through the shroud flange to get more clearance from the pump pulley. Used some sticky backed felt where the shroud touches the core,...might sound be a little thicker felt. Also cut the pulley bolt heads down & the shaft too, to be able to get a belt through with a small pry.
But, so far haven't been able to pull the Fan/Shroud without pulling the Rad, because of the inlet nipple. twocents
PS: I should've left the most outer flange (in that next to the last pic) on the shroud for better cosmetics,... & strength.
