Re: Another dzus question
[Re: DemonDust]
#2103262
07/03/16 09:26 PM
07/03/16 09:26 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
It looks like there are screw threads above the plate hitting against the other half of the dash. Maybe a set of rivets instead to hold the spring to the plate ( wide side if rivet on top of plate ).
[image][/image]
[Re: DemonDust]
#2103379
07/04/16 01:11 AM
07/04/16 01:11 AM
Posts: 11,606 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Now I see. The rivet in the button is sticking down and hitting the spring plate. Either the spring or the button needs to be reclocked with holes drilled in the tab for the rivet sticking through the button. There are plates made for that or you just clock your buttons around 90* and make your own holes. You can grind it down some and/or dolly it flat but it will still set up some and if you take too much off, you loose the clamp on the rivet.
[Re: DemonDust]
#2103657
07/04/16 03:22 PM
07/04/16 03:22 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
$70 or 80 from an aircraft supply place for a cheapy. Maybe find a decent used one on ebay. Lots of that stuff around with the economy and aircraft work in the tank. Any buddies who work in an aircraft or fab shop?
