Re: radio install wiring advice needed
[Re: mopars4ever]
#2103375
07/04/16 01:05 AM
07/04/16 01:05 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I believe orange is instrument lights. Put a meter on it and turn the lights on.
Not too sure there was a memory feed line in a 77 Volare, no memory to feed.
[Re: mopars4ever]
#2103402
07/04/16 02:04 AM
07/04/16 02:04 AM
Supercuda
About to go away
About to go away
up yours
Odd, you'd think the connectors would plug and play if it was specifically designed for a Chrysler setup. I've put factory 70's Am/FM/CB radio in my 87 Diplomat and it plugged and played no problem. I've also put mid 90's Neon radio in the same Diplomat, again plug and play. http://www.automotivetroubleshootingsecrets.com/car_stereo_wiring.htmlLooks like tan might be for the lights. Did someone stuff it into the same point as the red lead?
[Re: Sinitro]
#2103922
07/04/16 09:59 PM
07/04/16 09:59 PM
Supercuda
About to go away
About to go away
up yours
Identify the radio for year/car/model then we can help U.. Just my $0.02.. He already did
