radio install wiring advice needed #2103350
07/04/16 12:18 AM
07/04/16 12:18 AM
md
mopars4ever Offline OP
md
I want to install this radio in my 77 volare. I have the red and orange wire from the harness on the car but the radio I want to install has no orange wire. What goes where?
Re: radio install wiring advice needed [Re: mopars4ever] #2103355
07/04/16 12:26 AM
07/04/16 12:26 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you looked on line for a wiring diagram for that radio? The orange wire is normally a memory 12v constant feed. Some radios have a diagram etched into the case somewhere.
Re: radio install wiring advice needed [Re: mopars4ever] #2103364
07/04/16 12:52 AM
07/04/16 12:52 AM
md
md
I don`t know what year the radio is. The only number I see is 20C425 RCA and serial number. It is a Chrysler NOS 8 track am fm radio.
Re: radio install wiring advice needed [Re: mopars4ever] #2103375
07/04/16 01:05 AM
07/04/16 01:05 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I believe orange is instrument lights. Put a meter on it and turn the lights on.
Not too sure there was a memory feed line in a 77 Volare, no memory to feed.
Don't be the exception.
Re: radio install wiring advice needed [Re: mopars4ever] #2103384
07/04/16 01:19 AM
07/04/16 01:19 AM
md
md
The orange and red coming from the harness I`m good with but I don`t know if the tan wire on the radio should hook up to the orange. The orange should be for the radio lights and the red for power.
Re: radio install wiring advice needed [Re: mopars4ever] #2103390
07/04/16 01:34 AM
07/04/16 01:34 AM
md
md
looks like this one
http://www.worthpoint.com/worthopedia/vintage-nos-factory-radio-chrysler-522679421
After reading about it maybe it`s not a NOS chrysler radio but a replacement radio.
Re: radio install wiring advice needed [Re: mopars4ever] #2103402
07/04/16 02:04 AM
07/04/16 02:04 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Odd, you'd think the connectors would plug and play if it was specifically designed for a Chrysler setup.
I've put factory 70's Am/FM/CB radio in my 87 Diplomat and it plugged and played no problem. I've also put mid 90's Neon radio in the same Diplomat, again plug and play.
http://www.automotivetroubleshootingsecrets.com/car_stereo_wiring.html
Looks like tan might be for the lights. Did someone stuff it into the same point as the red lead?
Re: radio install wiring advice needed [Re: mopars4ever] #2103414
07/04/16 02:27 AM
07/04/16 02:27 AM
md
md
Red and tan are in the same plug, if that is what you were asking. Yeah, I don`t understand the wiring on the radio as the plugs don`t look like anything I have seen on a 70`s even 80`s Chrysler product. Since it`s a 8 track I don`t see the radio being any newer then early to mid 80`s.
Re: radio install wiring advice needed [Re: mopars4ever] #2103908
07/04/16 09:39 PM
07/04/16 09:39 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
A quick check on mymopar.com but their wiring diagrams only go to 76. The Volare/Aspen diagrams for 76 don't even show a radio connection.
Did you try http://www.forfmjbodiesonly.com/classicmopar/
Re: radio install wiring advice needed [Re: mopars4ever] #2103912
07/04/16 09:44 PM
07/04/16 09:44 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Identify the radio for year/car/model then we can help U..
Just my $0.02.. wink
Re: radio install wiring advice needed [Re: Sinitro] #2103922
07/04/16 09:59 PM
07/04/16 09:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He already did
looks like this one
Re: radio install wiring advice needed [Re: mopars4ever] #2104479
07/05/16 09:26 PM
07/05/16 09:26 PM
md
md
Ok, I bench tested the radio. The tan wire connected to the orange plug for the lighting and the red to red for power. I cut the plugs off and wired up the speakers. All working good. Thanks
