Re: best penetrant for 65 y/o brake lines
[Re: Mr.Yuck]
#2104392
07/05/16 06:44 PM
07/05/16 06:44 PM
Posts: 1,487 STL
cdstl
STL
I took a "toothbrush type" wire brush and knocked loose any external rust so that the penetrant could soak in. I then used a mix of 1/2 Acetone and 1/2 trans fluid and let it soak. I was able to break loose 13 45 year old brake lines and reuse the original lines.
Let it sit a day or two and keep squirting it in.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#2104524
07/05/16 10:22 PM
07/05/16 10:22 PM
RapidRobert
propane or acetylene? You might put the acet (sparingly) on it then shoot it while hot with some WD40 or whatever you have & see if it works
[Re: superchuck]
#2104908
07/06/16 02:11 PM
07/06/16 02:11 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Mix ATF with acetone 50/50. Way better than kroil. I'll give it a try since that stuff is nowhere to be found (except by mail) plus it is EXPENSIVE.
[Re: Mr.Yuck]
#2105835
07/07/16 07:26 PM
07/07/16 07:26 PM
Posts: 1,443 Maryland
Dads426
Maryland
Home Depot has acetone, plus I have a can of it at my house, right around the corner from you. Come and get it.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
