Trans options in a 70 E body #2104179
07/05/16 12:29 PM
07/05/16 12:29 PM
SC
V194 Offline OP
V194  Offline OP
SC
What Trans options are to back the Gen3 Hemis that will allow NO floor sheet metal modifications? What can be used with the stock console and floor shifter (Auto)
What are the Manual options? Again still retaining a stock look on the inside?
Re: Trans options in a 70 E body [Re: V194] #2104340
07/05/16 05:26 PM
07/05/16 05:26 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can bolt anything behind a Gen III you can a SB Mopar. 727,A833 etc.
Mopar to the bone!!!
Re: Trans options in a 70 E body [Re: 72Swinger] #2104477
07/05/16 09:16 PM
07/05/16 09:16 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This. You are basically limited to 70's era options if you are not going to consider any floor alterations.
There's the Passion 5spd, but you'd have to join the eternal waiting list.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N [Re: GoodysGotaCuda] #2105007
07/06/16 04:18 PM
07/06/16 04:18 PM
dogdays Offline
dogdays  Offline
P*A*S*S*O*N
P*A*S*S*O*N
P*A*S*S*O*N
P*A*S*S*O*N
P*A*S*S*O*N
Re: P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N [Re: V194] #2105017
07/06/16 04:29 PM
07/06/16 04:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have a couple customers with 44RH and 46RH with no floor mods in their e-body and at least 1 is a console, can't remember the other but neither had to mess with the floor just the crossmembers and grind a couple ribs on the OD case.
Re: P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N [Re: HotRodDave] #2105058
07/06/16 05:36 PM
07/06/16 05:36 PM
SC
V194 Offline OP
V194  Offline OP
SC
Now that is helpful. Thanks.
Re: P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N [Re: V194] #2131309
08/12/16 05:56 PM
08/12/16 05:56 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
anyone PUT A 700r4 behind one yet, this is the route I am considering in my A body for the OD non electronic. looks like physical size should fit.
Re: P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N P*A*S*S*O*N [Re: V194] #2141291
08/26/16 02:26 PM
08/26/16 02:26 PM
GA
roadrunninMark Offline
GA
Here is a great thread about the A518 (etc.) install.
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Re: Trans options in a 70 E body [Re: V194] #2141790
08/27/16 11:17 AM
08/27/16 11:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
A41 4spd auto, .070 OD from SST/Silver Sport Transmissions, no floor mods, tranny crossmember is a bolt in, factory slap stick retained, complete kit from bellhousing to driveshaft, converter, flexplate, speedo cable, tranny crossmember, mount, tranny lines, controller to program shift points/lock up, depending on what HP/Torque model you choose your going to drop $4500-$6500
You might want to check out their 6spd T56 Tremec E body conversion as well...
Re: Trans options in a 70 E body [Re: V194] #2144797
08/31/16 07:21 PM
08/31/16 07:21 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
If you decide to to get on the passion waiting list.(For the new 5 speed) Be aware that some have been on the list for many years now
He does have some beefier older overdrive (manual)
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
