Re: forged piston cylinder wall clearance
[Re: Moparnut426]
#2104168
07/05/16 12:13 PM
07/05/16 12:13 PM
Posts: 1,985 Apollo, PA.
B1MAXX
Apollo, PA.
@.007 you lose ring seal faster, from uneven wear across the ring face....but you won't hear anything until approx. .010.
[Re: Moparnut426]
#2104182
07/05/16 12:36 PM
07/05/16 12:36 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
This really depends on what the pistons were made for. Turbo/ supercharged,/ nitr pistons have more taper from top to bottom. That combined with stroke, bore length, and pin location all contribute to noise. If the skirt fits good, but a lot of the skirt is out of the bore at bdc, the piston will rock and be noisy.
[Re: Moparnut426]
#2104376
07/05/16 06:22 PM
07/05/16 06:22 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
My Diamond pistons are at .007". Well, probably more than that now...that was in 2006 when it was all new.
[Re: Moparnut426]
#2104683
07/06/16 03:50 AM
07/06/16 03:50 AM
Posts: 4,848 Memphis
HemiRick
Memphis
A friend of mine built a 383 w KB pistons and didnt tell the machinist. The engine sounded like a diesel. I just measured the clearance roughly with a feeler gauge and a .08 fit. Actual clearance was prob a touch bigger.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2104993
07/06/16 03:59 PM
07/06/16 03:59 PM
Posts: 4,457 Washington
madscientist
Washington
A friend of mine built a 383 w KB pistons and didnt tell the machinist. The engine sounded like a diesel. I just measured the clearance roughly with a feeler gauge and a .08 fit. Actual clearance was prob a touch bigger. You mean .008 because if you had .080 you could had slid a dictionary in there. Well, not quite but almost.
