Sbm Victor head results
#2103209
07/03/16 07:12 PM
07/03/16 07:12 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Does anybody have any track feedback.. I know there was Dyno numbers kicked around... I have heard a lot of good and bad things about these heads... nothing like real world results..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Sbm Victor head results
[Re: WHITEDART]
#2103278
07/03/16 09:58 PM
07/03/16 09:58 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Aren't the exhaust bolt holes in the wrong position? Lot-o-money for a bonehead mistake.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: dizuster]
#2103586
07/04/16 01:48 PM
07/04/16 01:48 PM
DARTH V8Я
Its a TRAP!
Exhaust pattern looks like a w2 to me. Nothing wrong with that. W2 header bolts are much higher.
[Re: WHITEDART]
#2103616
07/04/16 02:25 PM
07/04/16 02:25 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Headers will bolt up fine. Impressive Dyno results from the guy who did the Ritter deal. Can't wait to see how it runs when he gets it out
[Re: B3422W5]
#2103868
07/04/16 08:56 PM
07/04/16 08:56 PM
DARTH V8Я
Its a TRAP!
Headers will bolt up fine. Enlighten me on how NON W2 headers.. or even W2 (excluding W8/9) headers won't block a third of the port..
[Re: DARTH V8Я]
#2103871
07/04/16 09:01 PM
07/04/16 09:01 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Please don't sweat the small stuff guys. As hotrodders I'm sure we can come up with a quick fix if needed
[Re: MR_P_BODY]
#2103879
07/04/16 09:10 PM
07/04/16 09:10 PM
DARTH V8Я
Its a TRAP!
Please don't sweat the small stuff guys. As hotrodders I'm sure we can come up with a quick fix if needed I agree... a header flange is NOTHING Unless you need somebody to build a set... $$$ ... just saying.
[Re: WHITEDART]
#2103881
07/04/16 09:11 PM
07/04/16 09:11 PM
B3422W5
Portage,michigan
TTI is making( or has made) a header for this application
[Re: DARTH V8Я]
#2103891
07/04/16 09:21 PM
07/04/16 09:21 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Please don't sweat the small stuff guys. As hotrodders I'm sure we can come up with a quick fix if needed I agree... a header flange is NOTHING Unless you need somebody to build a set... $$$ ... just saying. Worst case would be a simple redrill re-tap. Been there done that
[Re: pittsburghracer]
#2103896
07/04/16 09:24 PM
07/04/16 09:24 PM
DARTH V8Я
Its a TRAP!
Please don't sweat the small stuff guys. As hotrodders I'm sure we can come up with a quick fix if needed I agree... a header flange is NOTHING Unless you need somebody to build a set... $$$ ... just saying. Worst case would be a simple redrill re-tap. Been there done that True that my friend. But on a $2k head?
[Re: DARTH V8Я]
#2103934
07/04/16 10:13 PM
07/04/16 10:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Please don't sweat the small stuff guys. As hotrodders I'm sure we can come up with a quick fix if needed I agree... a header flange is NOTHING Unless you need somebody to build a set... $$$ ... just saying. If you have to worry about simple headers flanges you better find a new hobby... you can make them yourself with a drill and air grinder if you want
[Re: MR_P_BODY]
#2103939
07/04/16 10:16 PM
07/04/16 10:16 PM
DARTH V8Я
Its a TRAP!
[quote=DARTH V8Я] If you have to worry about simple headers flanges you better find a new hobby... you can make them yourself with a drill and air grinder if you want Oh please Mike. Find a new hobby? LMAO. Where do you come up with this bullturd?
[Re: 72Swinger]
#2103942
07/04/16 10:19 PM
07/04/16 10:19 PM
WHITEDART
bean town ....Ca
the exhaust pattern.is a quick fix. Is it possible to go 8s in a 3000 pound car..with these heads N/A
[Re: WHITEDART]
#2103950
07/04/16 10:35 PM
07/04/16 10:35 PM
B3422W5
Portage,michigan
the exhaust pattern.is a quick fix. Is it possible to go 8s in a 3000 pound car..with these heads N/A Should be able to do that easily. 800 horse at 3000 pounds = solid 8's.
[Re: DARTH V8Я]
#2103960
07/04/16 10:49 PM
07/04/16 10:49 PM
MR_P_BODY
[quote=DARTH V8Я] If you have to worry about simple headers flanges you better find a new hobby... you can make them yourself with a drill and air grinder if you want Oh please Mike. Find a new hobby? LMAO. Where do you come up with this bullturd? Thats how I started building headers before I bought a mill... yeah it took hours to build a single flange.. but I didnt want to blow the money for a set
