Alternator bracket for small block #2103677
07/04/16 03:40 PM
07/04/16 03:40 PM
Virginia
Renan2601 Offline OP
Virginia
I'm looking for a alternator bracket for a small block mopar, It is a X block with Indy heads and a CSI electric water pump, I need the alternator to be on the drivers side if possible and a low mount would also be great. What are some good options
thanks
Re: Alternator bracket for small block [Re: Renan2601] #2103691
07/04/16 03:58 PM
07/04/16 03:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Driver's side low mount.
Hmm, what are you doing for a steering box?
What alternator do you have?
Don't be the exception.
Re: Alternator bracket for small block [Re: Renan2601] #2103826
07/04/16 07:25 PM
07/04/16 07:25 PM
Virginia
Virginia
Thanks for the reply, the steering box is behind the cross member, it's in a 70 Duster and the alternator is a power master but I'm not sure about the amp's
Re: Alternator bracket for small block [Re: Renan2601] #2103830
07/04/16 07:35 PM
07/04/16 07:35 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Look on the ARE website. Andy might have what you need.
Re: Alternator bracket for small block [Re: Renan2601] #2103837
07/04/16 07:51 PM
07/04/16 07:51 PM
Virginia
Virginia
Thank you, i'll check it out
