Page 17 of 48 1 2 15 16 17 18 19 47 48
Re: Modern Bullitt build [Re: Keepat] #2094156
06/18/16 10:20 PM
06/18/16 10:20 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
After removing the sound deadening held up with contact cement I was able to prep and prime the inside of the roof. Before spraying the epoxy primer and coated the inside of the roof framing with a rust encapsulator.
Pat
Re: Modern Bullitt build [Re: Keepat] #2094167
06/18/16 10:47 PM
06/18/16 10:47 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Then I prep and sprayed the floors and package tray. Next I’ll seam seal the floor.
Pat
Re: Modern Bullitt build [Re: Keepat] #2094308
06/19/16 09:43 AM
06/19/16 09:43 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Very nice!
What brand of epoxy are your spraying (SPI)?
Re: Modern Bullitt build [Re: Keepat] #2094323
06/19/16 10:29 AM
06/19/16 10:29 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Larry,
I'm spraying DuPont 2590S epoxy primer/sealer. Easy to mix and spray and lay down great!
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #2095843
06/21/16 08:23 PM
06/21/16 08:23 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I've been lurking around for awhile and I must say that your are the definition of hot rodding!
I am at a point where I'm thinking of pulling the plug on putting my paper weight together. Then I come here and you give me the bug again to finish it.
Thanks for the information on your build. You have inspired and educated me.
Matt
Re: Modern Bullitt build [Re: MattW] #2095987
06/22/16 12:46 AM
06/22/16 12:46 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Matt
Matt,
Thank you for your kind words, comments like yours inspire me to post the build.
Thanks again, now get out in the garage and finish your project ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2102546
07/02/16 04:14 PM
07/02/16 04:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Cleaned and painted the inside of the cowl and painted inside firewall along with the bottom of the Cowl. I use a paint that looks like the color of steel as this will make it a little brighter under the dash when working on it. With the car on the rotisserie it was very easy to use a self leveling seem sealer fill the original firewall panel seams.
Pat
Re: Modern Bullitt build [Re: Keepat] #2102978
07/03/16 12:44 PM
07/03/16 12:44 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Using some cardboard I mocked up the rear brake cooling vents. I will make these up using .065 aluminum and have them powder coated black. I will make up the discharge side at the brake when the rear and wheels are back on.
Pat
Re: Modern Bullitt build [Re: Keepat] #2103202
07/03/16 07:02 PM
07/03/16 07:02 PM
None
71rm23 Offline
71rm23  Offline
None
I just came across this build. I must be slow or something. Anyway, all I can say is WOW! I went through EVERY page. I'm blown away
Re: Modern Bullitt build [Re: 71rm23] #2103256
07/03/16 09:14 PM
07/03/16 09:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I'm slow also, been working on his car for over two years and I think I have another year to go ;-) thanks for checking out the build.
Pat
Re: Modern Bullitt build [Re: Keepat] #2105938
07/07/16 10:52 PM
07/07/16 10:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I made the aluminum rear brake vents using my cardboard template. After welding them together and grinding most of the welds down I used a air tool with a medium Scotch-Brite pad to finish off and smooth out the welds. The Scotch-Brite pad is very user friendly and fast when working with aluminum.
Pat
Re: Modern Bullitt build [Re: Keepat] #2107757
07/11/16 09:33 AM
07/11/16 09:33 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I think a NACA Duct in the torque box would do the same and belly pan the bottom of the car. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Modern Bullitt build [Re: HUSTLESTUFF] #2107899
07/11/16 02:28 PM
07/11/16 02:28 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
A duct in the bottom of the torque box would work great with a belly pan. But I'm not planing on putting a belly pan on this car. Hard to see and fix problems on a street car
Pat
Re: Modern Bullitt build [Re: Keepat] #2108414
07/12/16 12:56 AM
07/12/16 12:56 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Wow, you do some outstanding/thorough work.
Re: Modern Bullitt build [Re: UCUDANT] #2108973
07/12/16 09:06 PM
07/12/16 09:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you, it my therapy, but I think a psychiatrist would be cheaper ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2111991
07/17/16 07:30 PM
07/17/16 07:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Not a productive weekend on the charger as I went to Carlisle, but I did spray some hi build primer on the hood and trunk lid today.
Pat
Re: Modern Bullitt build [Re: Keepat] #2119911
07/28/16 04:12 PM
07/28/16 04:12 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Looking good Pat. Keep up the good work.
Re: Modern Bullitt build [Re: rhamson] #2121500
07/30/16 08:15 PM
07/30/16 08:15 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Hi Ralph, I hope you are well! How is your Challenger project?
Pat
Re: Modern Bullitt build [Re: Keepat] #2122020
07/31/16 04:58 PM
07/31/16 04:58 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finally I have removed all of the original paint and primer except for A small section at the center rear valance. She's all prepped and ready for epoxy primer just need the shop to cool off a little.
Re: Modern Bullitt build [Re: Keepat] #2122070
07/31/16 06:16 PM
07/31/16 06:16 PM
Central NC
gch Offline
gch  Offline
Central NC
I admire you patience,dedication,and skills.
