Re: Car lift for your shop
[Re: bobs69]
#2102847
07/03/16 05:00 AM
07/03/16 05:00 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Got one of each in the garage, 4 post is generally used for storage or minor maintenance like oil change and great for front end alignment.
2 post is used for major work...I love those lifts. Wish I would have bought one earlier but did not have the room for it.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: bobs69]
#2102861
07/03/16 08:25 AM
07/03/16 08:25 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I'm lucky to have two 4-post lifts in my garage. Perfect for storage as the suspension doesn't hang on the extended shocks like on a 2-post. Perfect for wrenching under the car as you have 2 long sturdy "tooltrays" to store tools and parts. Have never wished for a 2-post in all my years of wrenching on cars. Also get a little nervous seeing how instable some of these things look. And with most of my cars being 4500+ lbs fullsizers, I don't want to torture and flex their body-seems with a 2-post all the time. Besides, with a 2-post lift you gotta get on your knees 4 times positioning the arms...
[Re: 6T6Cuda]
#2103068
07/03/16 03:14 PM
07/03/16 03:14 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a two bay shop and each bay is 20' wide by 40' deep with 14' ceiling height. It has 18" thick concrete floors, so I could use a 2 or 4 post lift. At the moment I don't have either one, but when I buy one it will be a 4 post. I have more than one project to do and I will opt for the rolling jack tray and other accessories to do servicing. I am too old to be rolling around on the floor positioning lift arms.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: bobs69]
#2103156
07/03/16 05:43 PM
07/03/16 05:43 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
One odd point is if you can I would get the 14' version. The cylinder rams hit the top of the posts before you hit the header stop - but the car is usually high enough at this point. I planned on that (14' version) but not sure it will fit because my shop has a 14' ceiling and the literature says "For ceilings OVER 14'" So I'll need to get some clarity on that one before I order. I also don't know my exact ceiling clearance yet because the floor is not poured yet, should be done late this week. I also plan to go with the wide stance setup.
[Re: bobs69]
#2104015
07/05/16 12:15 AM
07/05/16 12:15 AM
Posts: 52 Texas
shart70rt
Texas
Have had a 4 post for about 8 years. Have not had many problems with access during my Charger's restomodding. I am 6'3" and have knocked a knot onto my head a few times. Very stable, have no worry about leaving the car raised for months at a time.
It is a 10k rating, and I paid less than 2k delivered with casters and lift shelf.
Bought it from a company in the Fort Worth, Tx area.
70 Go Mango Charger RT White Vinyl Top 18 Spline 4 speed Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing 505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
[Re: bobs69]
#2104564
07/05/16 11:34 PM
07/05/16 11:34 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
If you watch CL, used Mohawk lifts show up time to time-at good prices. An A6 will meet the needs of most home shops in rated capacity and height restrictions.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: J_BODY]
#2104998
07/06/16 04:08 PM
07/06/16 04:08 PM
Posts: 1,235 Chicago, IL
PLUM_72
Chicago, IL
If you're headed down the 2-post path, make sure your concrete floor is thick enough to handle the anchors needed to hold the thing down. Most garage slabs are only 4-inches thick at best. This really is not thick enough for a concrete anchor to support the weight of a loaded lift. 4-post is best especially if the lift is an after thought.
1972 Dodge Challenger
