Re: 400 block sonic numbers?
[Re: fbs63]
#2102807
07/03/16 01:52 AM
07/03/16 01:52 AM
Posts: 43,176 Bend,OR USA
Cab_Burge
I've sonic tesed over a dozen 400 blocks, no good patterns on year or castings dates I've seen Buy the blocks on a condition of passing your sonic tests, if the seller will agree with that go for it It will cost you for the soic testing(unless you buy the tester and and start offering your services to customers ) but nothing good comes cheap, ever. I bought a Dakota 1000 years ago, still have it and use it now and then as needed
[Re: fbs63]
#2103240
07/03/16 08:33 PM
07/03/16 08:33 PM
crabman173
crabman173
It is rare to find one that does not have one thin cylinder--last one I did I was sooo happy on first 7 holes then....the last one was awful--I put a sleeve in it and kept going- I say it is a crapshoot
[Re: ]
#2103277
07/03/16 09:57 PM
07/03/16 09:57 PM
dartman366
Mt. Vernon, Ohio
When I started looking for 400 blocks for my present 512 build I bought two and had both of them sonic tested and both had plenty of meat, one was a 1975 block and the other was a 1976.
[Re: fbs63]
#2103936
07/04/16 10:13 PM
07/04/16 10:13 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have several dates. All sonic test about the same. Usually one thin cylinder to make you sigh.
2011 Drag Pak Challenger
[Re: rickseeman]
#2104249
07/05/16 02:35 PM
07/05/16 02:35 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
I don't know how you fix a thin cylinder. Sleeve it, a ductile sleeve is stronger than the casting , problem solved.
[Re: fbs63]
#2104499
07/05/16 09:54 PM
07/05/16 09:54 PM
Posts: 5,160 Texas
dannysbee
Texas
If your boring is done with a cnc can they relocate the bore? Say take .005 off the thin wall and .025 off the thick wall?
Getting old just means you were smarter than some and luckier than others.
[Re: dogdays]
#2104973
07/06/16 03:20 PM
07/06/16 03:20 PM
Cab_Burge
It's been done.
There is an awful lot of anecdotal evidence that 400 blocks will have mostly good holes and one that needs to be sleeved. Those that need to be sleeved can be as 0.090" or less on parts of the bad hole. There shifting the bore won't work.
Would you pro engine guys say it's better to sleeve the hole first and then do the other block work?
R. Absolutely, push the sleeve in first and then bore and hone the rest of the block. Most machine shops use a .003 or bigger O.D. sleeve than the hole in the block to help seal it up, which distorts the cylinder walls on the one, ones, either side of it
[Re: dogdays]
#2104991
07/06/16 03:57 PM
07/06/16 03:57 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
R.
I ain't no pro engine guy but I certainly would do any repair first.
When it takes more than a sweet mullet to prove you rule at the trailer park..
