starter will not engage #2101869
07/01/16 01:51 PM
07/01/16 01:51 PM
CheddarHead till October
weedlayer Offline OP
wonder why?
spose I need a new case now
Re: starter will not engage [Re: weedlayer] #2101882
07/01/16 02:16 PM
07/01/16 02:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ouch
Re: starter will not engage [Re: weedlayer] #2101901
07/01/16 02:50 PM
07/01/16 02:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How in the heck did you do that
wave
Re: starter will not engage [Re: weedlayer] #2101909
07/01/16 03:06 PM
07/01/16 03:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Either something is flexing or the trans was not tight against the block..
Re: starter will not engage [Re: Al_Alguire] #2101919
07/01/16 03:13 PM
07/01/16 03:13 PM
The starter loosened up quite awhile back. Only a small portion of the break is fresh. Must have cracked way back and been working on it till mission accomplished.
Re: starter will not engage [Re: Al_Alguire] #2101922
07/01/16 03:15 PM
07/01/16 03:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing I can think of is that the starter
was ready to fall off and kicked it sideways..
bummer
wave
Re: starter will not engage [Re: weedlayer] #2102033
07/01/16 06:02 PM
07/01/16 06:02 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's an easy weld
Re: starter will not engage [Re: FastmOp] #2102067
07/01/16 07:29 PM
07/01/16 07:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By FastmOp
That's an easy weld
I agree... I'd burn that back on... I had a tail
shaft fall off my bench when I was building it and
cracked a chunk off... I burnt it back on and hit it
with a file.. no leaks... the only bad part.. you have
to pull the trans.... put some big Vs in it on
both sides and burn it in... I layed a straight
edge with clamps on it while burning
wave
Re: starter will not engage [Re: weedlayer] #2102451
07/02/16 12:09 PM
07/02/16 12:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
oh fart...... with the heat involved with welding would you want the case bolted to a block and a starter in place to aid in keeping stuff lined up? I certainly don't have the capabilities to do that work at home.
Re: starter will not engage [Re: J_BODY] #2102513
07/02/16 03:05 PM
07/02/16 03:05 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
JB Weld. laugh2
