Valve Cover Gaskets W-9 with big springs #2101095
06/30/16 01:15 PM
06/30/16 01:15 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Does anybody know of a narrow valve cover gasket that can be used with 1.680" O.D springs on a W-9 head that do not need to be trimmed to clear the springs?
Thanks!
Bill Lamb
Re: Valve Cover Gaskets W-9 with big springs [Re: 340Cuda] #2101096
06/30/16 01:19 PM
06/30/16 01:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks!
Bill Lamb
I used the MP gaskets(silicone over metal) and had
to grind for each spring... I havent heard of any
narrow ones
EDIT
I also had to clearance the reverse lip MP valve
covers
wave
Re: Valve Cover Gaskets W-9 with big springs [Re: 340Cuda] #2101119
06/30/16 02:06 PM
06/30/16 02:06 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Cometic makes a w9 valve cover gasket, and all pro makes a valve cover. W9 use the same bolt pattern as stock but they moved the front and rear rail. So if you want it to be correct get those.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Valve Cover Gaskets W-9 with big springs [Re: 1967dartgt] #2101865
07/01/16 01:48 PM
07/01/16 01:48 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Mike,
I was able to find some valve covers that I did not have to clearance, but was trying to avoid chopping the gaskets again.
Brett,
Thanks I will look into both of those gaskets, at least they may not need to be trimmed as much.
Bill
Re: Valve Cover Gaskets W-9 with big springs [Re: 340Cuda] #2101906
07/01/16 02:58 PM
07/01/16 02:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike,
Brett,
Bill
I never changed gaskets all the years I ran my
W-9 so I only cut 1 set
EDIT
I mod a set of MP cast covers
wave
Re: Valve Cover Gaskets W-9 with big springs [Re: 340Cuda] #2102842
07/03/16 04:06 AM
07/03/16 04:06 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mike,
Brett,
Bill
They will not need to be trimmed at all, they are the same width as the rail on your head.
Re: Valve Cover Gaskets W-9 with big springs [Re: 1967dartgt] #2102852
07/03/16 06:17 AM
07/03/16 06:17 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
How much was the top and rear rails narrowed? I am looking at doing some billet valve covers
Alan Jones
Re: Valve Cover Gaskets W-9 with big springs [Re: 1967dartgt] #2103142
07/03/16 05:27 PM
07/03/16 05:27 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Brent,
Am I correct that Cometic has two gaskets a W-2, W-5, W-7, W-9 model and a W-8 model?
I was expecting a W-9 only model and I am not finding it.
Thanks,
Bill
Re: Valve Cover Gaskets W-9 with big springs [Re: 340Cuda] #2103394
07/04/16 01:44 AM
07/04/16 01:44 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
C5784-60
This is part number you need for w9
Re: Valve Cover Gaskets W-9 with big springs [Re: W5DART66] #2103493
07/04/16 11:39 AM
07/04/16 11:39 AM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Originally Posted By W5DART66
C5784-60
"Cometic Midget & Sprint Valve Cover Gasket"
Thanks I never would have found it looking for W-9...
Bill
Re: Valve Cover Gaskets W-9 with big springs [Re: LA360] #2104047
07/05/16 01:52 AM
07/05/16 01:52 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Get gasket and use that as a template. They changed a lot.
Re: Valve Cover Gaskets W-9 with big springs [Re: 1967dartgt] #2113602
07/19/16 09:40 PM
07/19/16 09:40 PM
LA360 Offline
LA360  Offline
I found some info on the Cometic gasket site that I will use. I will have to order some gaskets to be sure
Alan Jones
