Reverse rotation clutch fan.... #210178
02/01/09 01:19 AM
02/01/09 01:19 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Any use for a reverse rotation clutch fan blade? The one I have (new) would actually be a pusher fan if I mounted it on my 383. Would there be any use for it , say on a reverse cooled SBC? Maybein a street rod?
Re: Reverse rotation clutch fan.... [Re: NTOLERANCE] #210179
02/01/09 10:16 AM
02/01/09 10:16 AM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
Wouldn't that sort of be like pi$$ing in the wind.?
Re: Reverse rotation clutch fan.... [Re: I go fast] #210180
02/01/09 10:33 AM
02/01/09 10:33 AM
Madison Wi
Madison Wi
Yes if used on a waterpump with standard roation. Do reverse cooled engines spin the pump backwards or is it a different pump impeller?
Re: Reverse rotation clutch fan.... [Re: NTOLERANCE] #210181
02/01/09 12:32 PM
02/01/09 12:32 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Most everything with a serpentine belt system uses a reverse rotation fan and pump. The clutch is different too.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Reverse rotation clutch fan.... [Re: gamagoat6x6] #210182
02/01/09 01:08 PM
02/01/09 01:08 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep..I've worked on alot of Chev C1500 trucks and they use a serpentine setup with a reverse rotation water pump/fan/fan clutch setup. (All the TBI ones, when they went to Vortec, they use a screw on fan clutch)
